hey fabricators
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fourwheelerjeff, Oct 3, 2003.
  1. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    i am wanting to run some hummer locks on my k5, i know you can run the dually front and not change the wheels, however the rear is the problem /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    how come someone can't make a spacer that fits the rear 14 bolt that fits tightly over the hub and space it out to match the front width, for that matter, could you make it where it would bolt to the hub for added stability
  2. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    run 'em backward and use the lug ring from those dually hubs to get you lug nut seat taper.
  3. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    but i am trying to let my bling run free /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
    seriously, i am still concerned with looks enough that i would like for the front and rear to be symmetrical /forums/images/graemlins/grin.gif
  4. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    I have some 3 1/4" spacers that I will be using on the rear of my K5 to run Hummer wheels. They came from a different company but they are identical to these;
    This style bolts to your existing wheel studs and then has a different set of studs to bolt the rim to. I found these @ Performance Wheel
  5. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    thanks, i thought about calling them, i have been to their place in denver before (back when i was stationed at fort carson) they had some swampers on welds back then that were used they were selling CHEAP, but alas, the army didn't pay enough to keep me and the wife happy /forums/images/graemlins/frown.gif
    so she left /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    PM K5BLT4FUN (layne)...he's running the sort of spacers you're talking about and you may be able to get some insight from him.
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    The first thing you have to work out is that the 14FF hub would have to be machined as the part you want to use to hold the spacer is just a cast surface. But if you have someone who can do this then I think that would do the job…I have my hubs machined true to the center bore /forums/images/graemlins/thinking.gif...and I have hummer rims /forums/images/graemlins/thinking.gif…and one hub for the front dana 60 that’s a DRW hub, would have to find one more…
    you got me thinking /forums/images/graemlins/thumb.gif
  8. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    thanks i will /forums/images/graemlins/thumb.gif
    another thing i have been told is that you can get some ford 2wd dually hubs and have them machined to fit over a 14 bolt hub /forums/images/graemlins/confused.gif
    anyone heard of this
  9. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    If you find a solution I'm all ears as well, I've been searching to do the exact same thing. Just talked to Casey from W.M.S. yesterday, but they didn't have a solution for me right now anyways. If you find a machine shop that wants to make something, and multiple units would bring the cost down, let me know. I'll keep looking as well. /forums/images/graemlins/thumb.gif
  10. fourwheelerjeff
    Nov 16, 2001
    3,419
    6
    i guess it wouldn't have to bolt to the hub, i was just concerned about running such a large spacer and was thinking of ways to add to the stability /forums/images/graemlins/smile.gif
    what can i say, i am cheap and trying to find the easiest way to run hummers front and rear, with a reasonable track front and rear and without the rear hubs sticking so far out past the tire /forums/images/graemlins/1zhelp.gif
  11. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Make it rear steer with Dana 60 DRW outers and away you go. OK, that is the long route.
  12. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    I ran across this link a while ago, don't know if it will help ya or not..
    rear spacers
  13. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    If you have a welder and the ability to use it well, and a keen eye for detail, Why not recenter your own hummer wheels? Thats what I'm gonna do. I'll be damned if I pay that much cash for something I can do myself, and do it better and nicer looking to boot. /forums/images/graemlins/thumb.gif
  14. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    I'll keep you in mind, why don't you start doing this as a service, there is a market for this, and yourattention to quality seems good so far, If I buy a set of hummers you could test on them for 1/2 the cost of usa 6x6 /forums/images/graemlins/deal.gif
    I save, you get a trial run, then start doing it for everyone /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/deal.gif
  15. TONYP
    Aug 13, 2002
    2,116
    so cal
    now that i can do...I would make them out of alum
  16. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I'd have to do it once on my own set of wheels before I'd be comfy doing it for other people. Lots of things that have to be exact. If I do something wrong on my own wheels...no problem. But If I do someone elses and something goes wrong....There goes my reputation. /forums/images/graemlins/thinking.gif hehe...One of these days when the time comes for me to do my own, I'll be sure to post up some details. /forums/images/graemlins/pimp1.gif
  17. supersize75
    Sep 27, 2002
    2,638
    How about I buy a set and pay for 1/2 of your set, then you recenter them both /forums/images/graemlins/deal.gif
    p.s. I am serious here /forums/images/graemlins/deal.gif
