Hey grill cutters...
Discussion in 'The Garage' started by sapper, Feb 23, 2005.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Got a question, i want to mount my winch as far back as possible, the bumper i made goes all the way back to the rad. i took a peak today to see about cutting it and saw that there was a vertical support going to the top of the rad, can this be cut or would something have to be put in?? TIA
    Here is a pic, Im talking about under the bow tie.
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    Both 72THING and I took that approach to mounting our winches. He cut his hood latch support intending to reinforce it later. It's now 2 years later and he hasn't felt the need. The blue truck is mine (as it looked a couple years ago). My front bumper is shaped sort of like a 2x4 flat against the framerails. I cut a piece of 1/2" steel plate to fit on top of the framerails just behind the bumper. The winch sits all the way against the back of the bumper and I just bent the hood support out of the way. In hindsight, I should have just cut it.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you could trim that without issue I'd say. That was my plan when I was building the K5. Glad to see someone planning to move the winch back. I hate to see winch bumpers sticking 10 foot off the front of a rig. As for eliminating that piece, I wouldn't. Trim it back but I wouldn't lose it entirely.
  4. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I built my bumper so the winch would mount under the core support. My approach angle is as good or better than with a stock bumper...
    I also like the fact the winch is pulling from directly between the frame rails.
    Rene
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You could cut it out and replace it with something beefier, but closer to the rad. That piece not only is used to mount the grille to, but it supports the center of the core support.
    I hear ya Sled dog, my winch sticks out Way too far. I have to approach waterfalls at a 45, and turn into it to clear the damn thing.
  6. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    hi- my winch is literally up against the radiator in my burban. i capped the frame and mounted my winch behind the frame cap, in other words my warn 9000 is almost entirely hidden behind the grille. I had to cut out the brace that runs straight up and down then cut out the support that runs along the bottom side of the grille. then i just neatly trimmed the grille to form around my winch and it worked out great. no wierd shakes or rattles and the approach angle is awesome so id go for it man. by the way i like your rig man lata ryan
