HEY GRIM or anyone else.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Nov 3, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    IS there anyway that I can adjust the float level without having to take the carb apart it si a stock qjet form an 85 with a 305?
    1985 GMC JIMMY
  2. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    You definitely have to remove the air horn, or you won't have a way of measuring the level. It's not that complicated. Just remove the accel. pump and choke linkages and remove the screws. It should come pretty easily. Adjust float level and the reassemble everything in the reverse order.
    if you are careful and don't lose any parts you should do fine.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  3. Grim-Reaper
    7,385
    Atlanta
    Bazer79 is right. the top of the carb has to come off. It can be done without completly taking the carb off the truck.
    Women dig dents and flat paint!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    Grim-Reaper
