Hey Grim - Thanks for the help.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Derf00, Mar 10, 2001.
  1. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I read your heater core replacement article and decided to just jump in and do mine which I thought just started leaking in the last couple of weeks. WRONG!!! It apparently has been leaking very slowly for quite some time, by the looks of the floor. At any rate, your article was a great help. As it turns out, if you know what you are looking for, the job wasn't to bad, just a waste of a good Saturday morning. The only thing I did contrary to your article was not droping the fender well. I found that with a socket, a universal joint, two extensions, and four hands I could reach the bolt. As luck would have it, both bottom bolts broke off. The clean-up and repair of the floor, padding, and carpet is a lot worse than the heater repair.
    Thanks for the good article.
    Derf00
    http://www.derf00.coloradok5.com
  2. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    Derf00, Hey can you give me a clearer picture of just what length your driver, and the bends for the univeral joints were. I already drilled the access hole in my fender a couple of years ago, but it pissed me off so bad, I am still looking for an answer. I often wonder whether the Mr Goodwrench had a special tool, made just for it, as I can't see dropping the fender well just to do it.
    If you ain't hurt, you ain't playin' hard enough.
    The General
  3. Grim-Reaper
    7,385
    Atlanta
    Glad it helped.
    General......GM put the box in before the front of the truck was on and didn't care what a pain it was 20 years down the line when it fails. Could be worse. I got a Supra also and I hear I have to remove the steering colum interior A piller garnish and the trim peice at the top of the windsheild inside hold those in. Then I can pull the complete dash to get to the core if it fails. I hear the dealer charges like $400 in labor to do the job.
    Diging it in the dirt with my K5's
    Grim-Reaper
    <A target="_blank" HREF=http://grimsk5s.coloradok5.com/>http://grimsk5s.coloradok5.com/</A>
  4. Derf00
    Jul 25, 2000
    1,683
    Abilene, TX
    I used a 10" and 4" 1/2 drive extensions, the universal and socket. The key element was the piece of electrical tape I wraped around the universal to keep it from flopping around when we were trying to stab the bolt. Which ever route you take, the job just plain sucks.
    Derf00
