Hey guys, I got a new ride...and have a small question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by morphed86k10, Apr 8, 2002.
  1. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Well, I went ahead and bought a new 'wheeler. Got a cherry '84 K30. Yep, I am as one ton as it gets now! It has a 4' lift, 35 inch BFG's, 4.10's, a detroit out back, a 454 and TH400 with 30K on them. He used it only to tow a car trailer (not much of a wheeler), and his sons convinced him to put the detroit in the back a few months ago. The front was lifted with soft springs which began to sag under the big block, so the previous owner installed TWO add a leafs in each spring pack, and a half inch block /forums/images/icons/shocked.gif. Well, it rides terribly, even with new skyjacker shocks. Luckily, the suspension doesn't move or the brake lines would have been maxed out I think. So I called up ORD this morning and ordered some Tuff Country 4 inch HD springs, stainless brakelines, and swaybar bushings. Shackle flip is in the future for the rear, but the cash flow is a little low right now /forums/images/icons/frown.gif. I'm working on getting some pics taken.
    Anyway, so I'm not off topic /forums/images/icons/smile.gif, would I really benefit from the heavy duty shackles with only 4 inch springs? It doesn't seem that the 4 inch springs are arched enough to come in contact with the frame.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    First off, if there is a block in the front you better be damn sure that it has a centering bolt going through the block so as to have it attached to the spring pack like the ORD zero rates or take it out immediately. As for the HD shackles, I would recommend using them even with a 4" lift.
