Hey guys I have a 4" lift I want more what to do?
Discussion in 'The Garage' started by Chrisblazzer89, Mar 2, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hey guys as you all can see from my sig I have an 88 k5 with 4" lift and 3/4 ton running gear. Now the thing is I just got some 38" TSL swampers and the 4" lift we need me to hack the h311 out of my fenders to fit these. I was wondering what can i do to get a 6" lift I don't want to spend a load of cash to do this. So far i think i can get a 2" shackle flip for the rear but what can i do for the front Steering correction/ lift/minimum hacking?
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Im not afraid of trimming but this is my DD and i want it to look good so hacking with a 4" lift i will have almost no fenders left I want to stop this
  3. Elevator Man
    Elevator Man 1/2 ton status
    Dec 23, 2005
    240
    Bigelow, Arkansas
    Zero rates + Little longer homemade front shackels=more lift maybe an add-a-leaf for the rear:wink1: :wink1:
  4. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Thanx Elevator Man.
    Keep the suggestions coming.
  5. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Most of the problem in the front arises from the front tire hitting the rear of the fender. I think zero rates front and rear and some trimming is the best plan of attack here. They will probably fit just fine in the rear. Thing about trimming the fenders is it takes some time to do a nice job. You can't just bust out the sawzall and have it look good. Get the 38s get zero rates and take your time trimming it will end up looking awesome
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Thats what I was thinking of doing I just wanted to see if there was anything else i could do.
  7. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    That`s really your only resort...hey, where are the pics?
  8. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    Zero rates and a 1" body lift? I think thats what I am going to end up doing. Either that or I am going to get 6" springs and zero rates for the front and a 3" shackle flip in the rear.
  9. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    another thing on the zero rates, like blazinzuk said most of the problem comes from them hitting the rear of the fender. with zero rates you can move the axle 1-1.5" foward to help with this problem.
  10. Ben B.
    Ben B. 1/2 ton status
    Sep 1, 2005
    352
    Central PA
    While we're on the subject, would moving the axle forward an inch or so with zero rates affect my front driveshaft at all?
  11. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I have the same questions. I don't mind cutting, as I already have and plan to more, but I want to get 2 more inches roughly economically. I understand zero rates are a good idea but what about driveshaft lengthing costs? Any steering considerations?
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    if you move the axle forward and down you will need to lengthen the driveshaft. best bet is to get a 1" body lift and a zero rate. If you wanna hack the fenders and make it look nice then flares are the way to go.
  13. Ben B.
    Sep 1, 2005
    352
    Central PA
    1" zero rate + moving axle forward 1" = driveshaft lengthening?
  14. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    yes. a stock driveshaft only has 3" of slip. one inch forward uses some of that and the one inch down uses some more. combined with the fact that there is already 4 inches of lift. as you lift the truck the shaft travels in an arch. so with 4 inches of lift the shaft only needs to be slightly longer but if you push the axle forward all that distance needs to be made up.
