hey guys put a tape measure to your tires
Discussion in 'The Garage' started by blazin_blazer, Feb 23, 2007.
  1. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    :confused: i just recieved a new set of 13/38-16 and they are just under 36'' :confused: .....:confused: 10'' rims
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Are they mounted? If so you need to go to the tire manufacturers website and see what size rim they were measured on. Also most tires do not measure the actual size as they are stated on the tire.
  3. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    they recomend a 8-10'' wheel! thats why i was asking for real measurements, to see how close the sizes were so you could have a set of radials and know what bogger 2 match the front for a romp or a tsl for a spare...u no what matches what....
  4. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Mine say 37 but they measure out at 37 and a 1/2 on a 10 inch rim
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    i had a set of 36x12.5x16.5 tsls. then got 38x12.5x16.5 tsls both mounted on same rims. 3/4 taller that was it.
  6. 01maroonz71
    01maroonz71 1/2 ton status
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    i've got 38x15.50 mud grapplers, and on a 15x10 wheel they measure 37.5inches tall.
    but they're brand new...if a tire is used, or balding, it will have more than an inch in height differenece.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Tires rarely are as tall as advertised. I think the 36" pitbull rocker is 36.1" tall, but that is the only one that comes to mind. My 39.5 Rockers are 38 3/4 on a 10 inch rim. They are advertised to be 16.5" at section width, but mine measure 17.2"
    If you run a wheel with less width, they will be taller.
  8. 01maroonz71
    Jan 8, 2007
    1,553
    4
    Palmetto, fl
    yeah, there are a ton of variables here...how new the tiresare....what pressure you run em at...and what width rim you run.....not to mention how heavy a truck is.
  9. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Yep, they are very rarely the advertised height.
  10. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    My 44x19.5x16.5 boggers on 16.5x12 wheels measure out at 43.5". Well that isn't exactly true, I have them on beadlocks now. So with the bead on the outside, the wheel is probably an inch or so wider.
  11. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    My 39.5 Iroks on a 10" wheel with 25lbs. o' pressure measure out at 38 1/4 tall.:crazy:
  12. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    well my hawgs which are horrible by the way are 38.5-15.5-15s and on 10 inch wheels only measure like 35.5 to 36 and one measures almost 37 inches(got me to)they all have same amount of miles on them haha, companies suck at using a tape measure to measure their own tires hahhahah, i think all their measuring techs are cross-eyed or something when the try to read the measurement
