hey guys, question?
Discussion in 'The Garage' started by Prime, Aug 26, 2005.
  1. Prime
    Prime Registered Member
    Aug 22, 2005
    10
    British Columbia
    on my 700r4 is it possible to put a bigger gear on the governor to make it shift faster, it still seems to rev pretty high before shifting.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    first make sure you TV cable is adjusted correctly then deal with the gov. You can change the springs in the gov to change shift points
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I dont mean to hi jack but what about the corvette servo. Ive heard about it but I'd like more info.
    Dustin
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the corvette servo is for the 700-r4 tranny it allows for more holding pressure on the 2-4 band. It causes a quicker harder shift into second. It is a very easy mod to do.
  5. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    I have a vette servo in my 97's 4L60E (wich is pretty much built like a JET tranny). It has a quick firm shift, but not overly harsh. Any time you have a smooth shift it basically means wear.. firmer shift = less wear. If the 700 in the 89 K5 goes... I'll probably do the same basic build to it.
