hey guys
Discussion in 'The Garage' started by blazin_blazer, Feb 7, 2007.
  1. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    is this true? i found a th400 output shaft and the guy says.."It was mated to a NP208 transfercase, but I believe it should fit a NP205 as well" is this true?
  2. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    c'mon guys
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    337
    Fort McMurray, Alberta
    As long as the TH400 is a 32 spline getup (which I do believe that the TH400 / NP208 combo was) you should be able to get away with it with the correct adapter. There might be issues with the length of the output shaft though...
  4. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    it is a 32 spline shaft
  5. blazin_blazer
    Aug 2, 2005
    4,043
    central arkansas
    i found ord has a wealth of info and most likely all the parts i need thanks tho
