Hey Iceman....re. klunking sound
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rh88k5, Nov 7, 2002.
  1. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    Hey Iceman, you said my idle may need to be adjusted? down Im guessing, but its fine. as far as backlash thats a possibility, how much should there be, and whats the best way to check?(10 bolt)
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    What combo tranny/Tcase do you have?
    if you try and turn the yoke does it have a lot of play? more than 1/8-1/4"?
  3. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Your Tcase is the 208, it has that problem of clunking from the slip yoke, do a search on that it was discussed a lot in past week, maybe 2.
    As for the axle check for play when you block the tires and shift in neutral. You shouldn't have more than a light wiggle.
  4. rh88k5
    Sep 11, 2002
    94
    Burlington, N.J.
    yeah, its got atleast a good 1/8 of rotation. it seems like when I come to a stop, the truck "rocks" back abit, and thats when I hear it, then again when I take off, not very loud but, I notice it and it bothers me.
