hey kenny
Discussion in 'Pacific Region' started by leadfoot067, Sep 22, 2003.
  1. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    you seem knowledgable on the old chev rear ends..thought you might know this stuff... on the old eaton rear ends...it came from a 68 chev has a detroit and 456 gears..coil springer...is the overall width the same as dana 60 rear from a 72 gmc? my 60 in the gmc is shot...i can get the eaton for nuthin....other than the spring pads what are the differences??
    thanks
    shane
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    What is it going into? 2wd, 4x4?
    WMS to WMS should be the same. You may need to add shock mounts and spring pads but it isnt going to be a big problem. Brake parts are not the same between the Dana or Eaton axles but most of the important measurements are.
    You can also upgrade the Eaton with Corp 14FF axle shafts and carrier gears to get 31 spline shafts.
  3. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Shane, PM Don in Spokane, he has eatons, and has thm there answers /forums/images/graemlins/thumb.gif
  4. leadfoot067
    May 14, 2001
    1,563
    well by the looks of it i thought it was all pretty close....just needed confirmation...thanks man /forums/images/graemlins/thumb.gif
