Hey Marv..
Discussion in 'The Garage' started by Confedneck, Jul 21, 2003.
  1. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    about the springer setup..i bet someone can answer this for me...is it feasable to run a 4" ford lift spring with the springer setup? i want about 8" of lift or so..and thought that might do the trick?? thanks to anyone who helps..
  2. Grim-Reaper
    7,385
    Atlanta
    Yeah you could proably do that. The lift spring will be a bit stiffer then the stock spring so it won't flex as well. It's also probably going to cause some Geometry issues with the track bar Marv sells with the kit. May also have troubles with getting a shock to deal with that mutch lift with out doind some custom work.
  3. Confedneck
    Nov 1, 2002
    5,236
    would having the track bar lengthened take care of the geometry issue? also im looking at mounting in bilstiens with remote rezzys and some custom bootiefab anyways...
    i guess i could always stick a 4" tapered block in, but i HATE blocks almost as much as i dislike body lifts...
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i ran my shocks like this:
    and the lateral control allows me to not use the track bar. it might help, but its good enuff for 500 mile trips.
  5. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I like that set up Zakk. But I need the use of my back seat and rear cargo. But your is cool. /forums/images/graemlins/thumb.gif
  6. SF87K5
    Oct 27, 2002
    1,105
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    people have made back seats work in some cases.
  8. SF87K5
    Oct 27, 2002
    1,105
    Cool Thanks Zakk /forums/images/graemlins/thumb.gif
  9. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Hey Josh...
    Sorry, but presently I don't have a way to get you up to 8" of lift... 6" is about as high as you can go with the 57's and my setup, and adding blocks is really not an option because of the soft spring rate.
    If you're patient, you may soon see a Springer setup that runs 63" springs, but requires moving the front spring mount - and that setup may (don't really know yet) be able to get to 8" of ride height and still have some useful travel.
    BTW, I hope FlexyK20 and RyanB see this too!... /forums/images/graemlins/deal.gif.. cuz they've asked me the same thing!
    Marv
  10. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Did i hear my name? /forums/images/graemlins/grin.gif
    Sweeet... /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  11. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Marv are you making any more kits to be used with ORDs flip??
  12. Confedneck
    Nov 1, 2002
    5,236
    so 160$ for the echobit adaptation kit...or wait and see what marv comes up with? ill wait since i dont even have my new axles yet...time is something i have plenty of...
    the springer kit looked like the way to go for me...but now i gotta wait..DOH
  13. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    One option since you be swaping axel anyways is to net 6 inches with marves current set up and while you have the axels out weld a higher spring perch, the leverage or tendency to spit out the block wouldn't be there, although I am shure this would alow further axel wrap. /forums/images/graemlins/thinking.gif
    Dare I say it.....body lift? /forums/images/graemlins/ignore.gif
    Seriously though, Marve's kit has alot more to it than what meets the eye and once you see it work you will be sold on the engineering behind it.
    I am curious about the 63's too /forums/images/graemlins/thinking.gif
  14. marv_springer
    Aug 3, 2001
    2,781
    Mesa, Arizona
    No... But I'd be glad to send you a free set of stock frame brackets if you like /forums/images/graemlins/grin.gif....
    Marv
  15. sapper
    Jul 11, 2001
    3,052
    NoVa
    it was to much time and cussing to get the flip on, it damn sure isnt going to off on purpose /forums/images/graemlins/rotfl.gif
