Hey Sandman...Where is our pics???? hmm?
Discussion in 'The Garage' started by supersize75, Apr 28, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    There have been rummers latly from "unidentified sources thatyou were able to sucessfuly raise your gas-tank.
    I have a 3 inch body lift as well and will be getting custom bumpers soon and I wont have that good ole reciver hitch to protect me so.....
    Where is the write um man? Dont hold out on us! /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    Re: Hey Sandman...step in here please
    my ears are open as well /forums/images/graemlins/ears.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Ah yes. I have done this. /forums/images/graemlins/grin.gif
    I didnt take any pics as I was burning midnight oil trying to get it done but I did do it.
    This is how I did it:
    - Pulled off the rear bumper.
    - Pulled off the hose to the filler neck.
    - Put a floor jack under the tank and removed the 4 bolts and then pulled out the straps.
    - Lowered the tank an inch or so, so I could get to the hose connections easier. Undid the hoses and the wires.
    - Dropped the tank.
    Now the trick is to raise up the crossmembers. But first you have to remove them from the frame. Now this is a real bitch to do and was the hardest part of the whole thing. I dont have a torch so I rented one for $15 and blew out all of the rivits that hold in the crossmembers.
    I was planning on cutting out squares of 3" and welding them in. I decided not to in case I ever wanted to remove the body lift for any reason so I decided to use spacers with new long bolts to space up the crossmembers. I found a peice of thick wall pipe at work and cut 14 pieces at 3" long. Got 14 bolts and nuts and stuff and spaced everything up. I was worried about the spacers allowing the tank to shift around but the Crossmember mounting points are staggered forward and back. Then the tank is sorta jammed up higher in the frame so I dont think its going anywhere. Anyway, It worked out well and I went through week in Moab with no trouble. Anybody who watched me go through Upper HellDorado knows that I didnt baby it.
    If your interested, I'll get some pics together or let me know if you have any more questions and I'll do my best to answer them. /forums/images/graemlins/grin.gif
    Oh yeah, The gas tank seam had to be wiggeled some to get up in the frame rails but it fit fine.
  4. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Who turned me in? /forums/images/graemlins/rotfl.gif
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I dunno but it looks as if they like rum, Pirates maybe??? [ QUOTE ]
    [/ QUOTE ] /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
  7. supersize75
    Sep 27, 2002
    2,638
    oh I cant say,, but he might like rum, but HE SHuURE WAS NICE BECAUSE HE PASSED IT tHe ruM TO ME AND i still cantt typed I so fawked up, good shizt, piks pleasee /forums/images/graemlins/crazy.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I'll try to get some pics tonight for ya. /forums/images/graemlins/thumb.gif
  9. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    I was gonna swap in a blazer tank into my pickup to eliminate the smashed up, leaky saddlebag tanks. I should be able to raise it in the frame the same as you did, right? Also, which has more capacity,Sub or Blazer tank, or are they the same?
    Thanx
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    You could get bigger tanks in the Subs. I think that they are longer is all.
    I think the biggest problem you will have is drilling the holes in the top of the frame. Cant get a drill in there strait. Might have to pull the bed or just do some welding.
  11. K1Orion
    Jan 8, 2003
    812
    st.louis,MO
    I was gonna do it when I swap the bed, the one I have has holes big enogh for small children to fit through in the floor.
    It will also make getting the saddlebag tanks off MUCH easier.
    Thanx for the info!
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Without the bed, raising up the tank should be a snap! /forums/images/graemlins/thumb.gif
  13. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Heres mine lifted.
    from the side you can see the how much higher it is.
    -Jeremy
  14. supersize75
    Sep 27, 2002
    2,638
    dude, you never posted pics of the spacers, I need a visual!!!
    [patiently waiting]
