Hey Steve...CB Antenna Mount
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by johnny reb, Aug 7, 2000.
  1. johnny reb
    johnny reb 1/2 ton status
    Mar 6, 2000
    326
    Pittsburgh, PA
    I was checking out the small window sticker in the merchandise section and I noticed that you have a bumper mounted CB antenna. It looks like maybe a 5' or 6' whip antenna. I just got a 4' whip which I mounted on the right side of my rear bumper. I'm having trouble getting a good SWR reading. I think I need a longer antenna. How well does yours work? What kind of setup do you have? Thanks
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am running a 4' Wilson fiberglass whip mounted directly under my passenger side tailllight(about 2"'s above the bumper) and I have no problems. As long as you get some of you antenna bove the vehicle it will be fine.
    Mine sticks up past the roof about 4inches or so.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Best place to get even coverage to mount an antenna would be the center of the steel roof panel. second best would be the center od the hood, 3rd would be 2 on both sides. Any time you mount the ant. on the corner ike the bumper the steel panel will interact with the ant. and phase it, or point it out from that point. in Emmettology case his best covrage is to the right rear. with almost no covrage to the left ft. have in the wipe up higher would help but at 11 meters and 4.5 watts the hole is big. By the way the shells are not seen by the antenna only the steel panel count!
    I understand the jeep thing I drive a BLAZER!!
    Ken
  4. Emmettology 101
    May 9, 2000
    8,126
    FL
    My mount works just fine for me. I usually only use my CB when on trails or during a convoy to a trail. I have never had any problems with my set-up even a distances over a mile.
    Mike [​IMG]
  5. blazer72
    Apr 13, 2000
    939
    KCMO
    Didn't mean to say anything bad about your set up my CB ant. mounted in much the same place , it even works all the time now that I replaced the mount and cleaned the ant ground at the mount. Now my 2 meter is mounted up front on the filler panel just behind the hood just like the am/fm ant. only on the right side.
    Ken
  6. CK5
    May 19, 1999
    21,622
    701
    CO
    Well, right now it really sucks, I have to check the groud first, one of my next mods is to install a roof/rack basket, at that point I will install one of those little antenna's similar to what the guy at allprooffroad.com runs on his 4-runner.
    Steve Fox
    90 3/4 ton K5
  7. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    Steve, What kind of roof rack are you looking at. I got a wilderness Rack with the floor, hi-lift and rain gutter ounts as well as lights front and rear. very pleased with its duribility and strength as well as lots of options (gas and water tanks, ax, shovel, tire, multi ax, and anything else you can think of) Just curious, would be glad to pass any info on to ya if needed.
    PS Also put on on my gf's Tahoe, worls great on her's too.
    Ben
    www.BenjaminBone.coloradoK5.com
  8. johnny reb
    Mar 6, 2000
    326
    Pittsburgh, PA
    How did you ground your mount? I drilled a 1/2" hole in my bumper and placed the mount directly in that hole. Isn't that grounded? Or should I run a wire directly to my frame somewhere? I just put on my 4' whip on this weekend and I get ok reception around town, but I haven't tried it on the open road. I currently have an SWR around 2, which I guess is ok. I'm afraid of burning out my radio if I don't have the antenna mounted correctly.
  9. CK5
    May 19, 1999
    21,622
    701
    CO
    Hopefully, I will be getting a Yakama "Load Warrior" for review here pretty soon.
    Steve Fox
    90 3/4 ton K5
  10. Bone85K5
    May 7, 2000
    436
    Columbus, Georgia
    Those are great racks, really like their looks but for my use the wilderness has better function. It can acept any Yamaka or Thule bike,canoe, or any other adaptors they offer as well as a crossbar. The few can-backs I have seen llok sweeeeeet with Yamaka racks though, good luck cannt wait to see it. Are you going with lights or any other attachments?
    Ben
