HEY STEVE!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by yeild2me, May 31, 2001.
  1. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    you have pretty much the same set up as me (at least from the t-case back, including suspension). what measures did you take as far as drive line angles-i.e.-shims, cut and re-weld perches, drop t-case, CV shaft etc. i have this killer vibration that i had almost figured out, then the next wave of mods came along and my rear is about 1.5 inches higher thn it was due to the weight reduction ( top and tailgate permanetly removed) now my angles are off again, and was just wondering what you had going. i really dont want to replace my 4 degree shim with a 6 degree shim or drop my t-case anymore than the factory spacers, but i am going to try both before going to a CV shaft. BTW-the shims are to shim the pinion DOWN.
    thanks rob
    AIRBORNE!!
  2. CK5
    May 19, 1999
    21,626
    703
    CO
    Right now my 241 case is lowered 1-1/2" with no vibration, that will all change with the new setup however. Anyway I would look at putting the tcase in the stock location and going with a CV driveshaft.
    Steve
    Bandwidth FREE ZONE
    Mall-Running poseur 4x4 with curb-feelers
  3. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    OK Steve, you have probably mentioned this but what mods/upgrades are you doing to the drivetrain? I also have the 241 and was a little disappointed that there was no slip yoke elimination to the CV joint DL. My buddy - one of Jess's official testers - said that they have an extended slip yoke that works well.
    Dave
  4. CK5
    May 19, 1999
    21,626
    703
    CO
    I have a TH400/NP203/NP205 sitting on my garage floor.
    Steve
    Bandwidth FREE ZONE
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    OH - going the heavy duty route! Cool but after your write-up, I know I'll want one!
    Dave
