Hey stickseller, what kinda sticks do I need...?
Discussion in 'The Lounge' started by chevyfumes, Feb 12, 2004.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    What all will I need for the carport, I'm gonna use corrigated roofing sheets....So I need flashing, pier pads and how many and what kinda sticks, I do realize I will need an extra 4x4 post in there... /forums/images/graemlins/doah.gif /forums/images/graemlins/waytogo.gif [​IMG]Fawkin thing... /forums/images/graemlins/thinking.gifIt's 32' long 9' high at the shop wall and 7' at the outside... /forums/images/graemlins/waytogo.gif
  2. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    Check Here
    How deep is it? and is it open on 3 sides?
  3. chevyfumes
    Feb 24, 2000
    38,584
    266
    [/ QUOTE ] 9' to the posts and 9'6" to the end of the rafter tails and yes its open on 3 sides....
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    Check Here
    [/ QUOTE ] Whaaa, you didn't like my detailed plans, I'll have you know it took me 15 minutes to draw those on paint.... /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gifBut they wouldn't resize for [darn]... /forums/images/graemlins/thinking.gif /forums/images/graemlins/whistling.gif
  5. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    I belive your mosty Doug-Fir up ther so a 2x6 @ 24"o.c. will work for the roof (I'd personaly use 2x8) /forums/images/graemlins/grin.gif I'd use a ledger to secure the roof to the building with hangers. And probably a dbl 2x8 beam on the outside wall. Span Chart
    So you'd need:
    3 4x4-10 for post (assuming 2-3' in ground)
    3 2x8-12 for the ledger
    6 2x8-12 for the beam (doubled up)
    17 2x8-10 for the rafters (thats close the actual diag is 9-8 1/2" so if you were to go with 12' you could use the off fall for blocking)
    3 4x4 post beam connectors
    17 rt-7 hurricain ties for the rafters
    15 2x8 joist hangers (notch joist to fit its cheaper than a sloped hanger)
    4 MPA-5 Corncer brackets
    50' of 16" flashing
    12 Ice Cold Corona for each day of work
    You could switch to 6x6 for the post and notch them to hold the beam that might help with lateral roll and for 3 it wouldnt ad much cost /forums/images/graemlins/grin.gif Use the off-fall from the rafters to block at 4' from the wall, this would be like a purlin to help stiffen the metal on the roof /forums/images/graemlins/thinking.gif
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Thanks bud, you've givin me some good ideas, I'll be bumpin it down abit since there will be no one walking on this roof and it will be for summer storage only.... /forums/images/graemlins/thumb.gif
  7. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    If they sell it up your way check on Ondura for the roof. Its a composit and for the life of it you have less maintenance and it will last alot longer
    Oh yea...add a 4x4 or 6x6..I forgot the 1st one /forums/images/graemlins/blush.gif
  8. chevyfumes
    Feb 24, 2000
    38,584
    266
