Hey will 2000 3/4 ton wheels work on my 86 Silverado?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Silverado4x4, Feb 18, 2001.
  1. Silverado4x4
    Silverado4x4 Registered Member
    Oct 2, 2000
    Illinios, southwest of chicago
    they are 16x7 eight lugs which i will need when i swap axles. 1st question: are they the right offset and bolt pattern?
    2nd question: Can i just take the center caps off in front for the hubs?
    3rd question: Whats the widest tire i can fit on a 16 x7? I have the factory wheels now (rally wheels with trim rings) which can't be any wider than 15x7 and i have 33x12.5 on them. They work fine.....
  2. Cavalry
    Cavalry 1/2 ton status
    Oct 1, 2000
    upstate NY(although I cant figure out why)
    This is just my opinion but.....I tried to put the wheels off my 98 z71 on my K5. sure its a 1/2 ton and different than what your are doing but the offset was WAY off, IMO the hubs hanging out the center of the wheel looked really goofy and I think they would really catch in the rocks etc.
    84 K5
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    Austin, Texas
    The 8 lug rims shouild bolt up to any GM 3/4 ton 8-lug axle with no problem.
    I personally would not run a 33"x12.5" tire on a 7" wheel though; but that's just my opinion.
    Do you have a lift? If not, they will most likely rub the inner fender walls when wheeling.
    When I did my 10 bolt to 14 bolt conversion, I opted for 15"x10" wheels; and they are a perfect fit for my 33"x15" tires on a 2 1/2" suspension lift.
    Good luck in whatever you decide,
    -- '84 K5 Blazer --
    <A target="_blank" HREF=http://Stoopalini.coloradok5.com>http://Stoopalini.coloradok5.com</A>
