Hheellpp!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmanblazer, Apr 12, 2005.
  1. dmanblazer
    dmanblazer 1/2 ton status
    Sep 5, 2004
    165
    Wellington, Kansas
    My '79 K5's rearend (12 bolt) is making noise when I let off the throttle, even when I put it in neutral. It is a (getting louder & louder>) knock.
    When I dropped the driveshaft I found that there is a 1/2" of slop in the pinion when I tried to rotate it.
    I haven't messed with a rearend before and I'm thinking about rebuilding it myself, I built the engine so I know I can do this, but I may need a little input.
    How long should it take?
    What are the major parts to be replaced?
    I don't have alot of money, but I'd like to install a posi carrier, stay with the 3.73 gears, and if at all possible reuse my axelshafts.
    Any suggestions guys?
  2. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    If your up for a 800 mile drive I have some 3/4 tons I wanna get rid of
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Did you try tightening the pinion nut ? 12 bolts back off sometimes , one of mine did too . Luckily I caught it before it got bad . Worth a look if you want to save some money for now . Worse case is axle swap , but that isn't too bad either .
