HHHEEELLLPPP!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dbltapp, Mar 22, 2002.
  1. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    Something is not well w/ my burb! She ran fine last night, this morning i go start her, to let her warm up for 15 min, come back, put it in gear , and she feels like she is running on four cyl. I get it aroun the block, and she is buckin and lurchin. The check engine light comes on, so i shut her down, start her up again, no check engine light. She won,t idle in gear, idles rough in park. Last night was the coldest night we have had for awhile. I have a 95% full tank? Does anyone have any ideas? TIA.
  2. dbltapp
    Apr 25, 2001
    133
    ANYONE ?
  3. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Sounds like a vacuum leak. Check all vacuum hoses around the carburetor.
  4. dbltapp
    Apr 25, 2001
    133
    Thanx. It's got TBI, so it shouldn't be a vacum leak? I just drove it around the block, and now i am leaking tranny fluid from my aux tranny cooler, WTF?
  5. dbltapp
    Apr 25, 2001
    133
    Anyone?
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    You could go out and spend $30 on some fancy boy scanner, or spend 1 cent and use a paper clip.
    <a target="_blank" href=http://www.sportmachines.com/maintenance/aldl.html>ALDL Codes</a>
    What you do is turn your ignition is off. Look for the plug for your code scanner near the parking break release. Take the paper clip and stick the ends in the two holes in the upper right corner. Turn the ignition on, but don't start it. Watch your check engine light now, it will talk to you. It will blink once, then wait, and blink two times fast. Then it will wait longer and do that again two more times. It just told you 12, it will blink each message three time. Twelve means that it is begining the diagnostic. After 12 has blinked, it will begin to blink your error codes. There's no need to do this while the check engine light comes on during the problem. Your computer is smart and will remember until you unhook the battery. Don't start the truck with the paper clip installed.
  7. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    there are so many things it could be. check all the wires and the cap, be sure to inspect the cap for signs of a cross fire, same thing happened in my last dodge. besides that spray some starting fluid around the base of the tb if the idle raises then the fluid is getting sucked in, so you may have an intak/vacuum leak. besides that it could be the coil or the computer.
    good luck
    Ryan
  8. dbltapp
    Apr 25, 2001
    133
    OK, thanx for the help, i found out why my aux tranny cooler is leaking, and it's not related, at least i don't think so. At least everything you guys are saying is less expensive then what i am thinking.
  9. tRustyK5
    Jul 23, 2000
    36,170
    1,380
    E-town baby!
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    How cold? Maybe there's a bit of water in the fuel and it froze?
    Rene
  10. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I to would do the paperclip thing and then post that code that it gives ya.( I know the codes where in the chilton for my wifes old car but not sure if they at=re in the chiltons for yours)
