Hi amp alt question
Discussion in 'The Garage' started by surpip, Aug 19, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    so if i put a 140 amp alt on my rig, and i dont really "need" it, will i fry anything? Like if i dont have the draw to where i would need to step up to a bigger alt. will i fry stuff if i just run it?
  2. Dallin
    Dallin 1/2 ton status
    Feb 12, 2003
    135
    No, you won't fry anything. It never hurts to have more alternator then you need. The voltage regulator ensures that the alternator makes the appropriate amount of power for the demand.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    sweet thanks
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    What he said, it won't hurt a thing :thumb:
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    glad you got it to work..... I was unsuccessful... gonna re-visit it later....
  6. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i havent put it in yet, i was just asking before i went and spent money on the bracket at the dealer
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    bracket? are you replacing the stocker on a sb350? mine fit right in... are you doing the pontiac transsport? I had no success with that.....
  8. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    no it is a large case GM alt.
    i need a bracket from the dealer, like the ones on the cop cars(someof them)
  9. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    Ya might want to contact RJF on that one,,,,i know he installed something like that , to power all of that fancy sterio stuff he has. :D
  10. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Alternator Bracket
    Yeah, He's right I had a Serp Setup from a 9C1 cop car and the ear was broken off of it. The new bracket was like $65.00 from my chevy dealer in Charlotte mainly used in this application and does require the extra bracket. I still have this setup and when I get ready to put it on then I will have to get this bracket also, just check between the 90-93 year models, with either the 5.0 or 5.7.
    Just my 0.02, Jeremy.
  11. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    Alternator
    Without knowing what your year or model is, I'll use mine as an example. On my 79 Jimmy with a 350, it has a weenie 60 amp alt, but if you ask for the alternator for an 83 Caddilac Cimmaron, it's a 100 amp unit, same case and clocking and plug in as the 60, and it's a GM part #. Just a my 2 cents for folks wanting to upgrade to a higher amp alt that will bolt and plug right in.
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    yep thats the one i need
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    At full load the stock primary loop (8ga) is not up to the task of delivering 140 amps. I fried mine and had to rebuild it with 4ga wire.
    It won't hurt anything till you really need all the power it has.
    Just my .02
  14. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    really? wow i figured the 8Ga would be enough
    a little 4Ga extension wouldent be that expinsive though
