hi amp alternator w/ stock battery
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scott87, Aug 22, 2002.
  1. scott87
    scott87 Registered Member
    Feb 7, 2001
    39
    basalt, colorado
    Any problems with using a hi amp alternator (say 140 amps) with relatively stock battery (around 700 cca)? I thought I read somewhere that if you upgrade your alternator you should upgrade the battery as well. The stock amp on mine is 94 amps, I think (94 A is what's stamped on the case). Any thoughts? I ask because a 94 A is about $150 here, and a Powermaster 140 A is right in that same range. Don't really need the extra amps, but for the same price, why not?
  2. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    You won't have any problems what so ever. The alternator will only put out as much power as is demanded. I got my 140 amp powermaster from Kpanza (aka Keith). Shot him a PM and he should be able to save you a few bucks.
  3. dyeager535
    26,978
    My only thoughts are, if its not broken, don't fix it, and secondly, if it is broken, a rebuild kit is about $15.
    If you aren't running anything additional electrical load wise that requires it, I don't see any point in going way beyond what you need. Just my opinion of course! : )
