Hi LIft Jack, how to lift the front....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bone85K5, Jun 2, 2000.
  1. Bone85K5
    Bone85K5 1/2 ton status
    May 7, 2000
    436
    Columbus, Georgia
    OK, so I am not the most experienced driver. Wondering where most jack the front of their trucks up (or the side) with a Hi-Lift. The rear hitch mount seems to work good for the rear but the rest is what I am wondering about..
    BBone 85'K5
    Wilderness Roof Rack in the winter, Skyler in the summer...
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I have used the bumper hook assesorie sold buy HighLift on my stock bumper but now that I have a winch bumper I just lift under that...
    Rock ON![​IMG] 72 K5 [​IMG] Led Zeppelin
  3. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Bone,
    For the front, I position my HiLift jack in the middle of the front bumper and jack it up. Then I put Jack stands underneath on the front axles or frame for stableness. If it aint directly in the middle, then the jack might start to lean. Learned that from experience.
    Boss
  4. Burt4x4
    6,854
    On that note about leaning I bought a ConFerr base plate for my HighLift and now that narrow base is no more and I can use the jack at an angel and it still stays standing!!
    I even used it in a river bed on some rocks and I would recomend a bigger base plate to anyone using a highlift on the trail!!
  5. BillR
    BillR 1/2 ton status
    Mar 15, 2000
    164
    Flagstaff, AZ
    I lifted mine tonight with the HiLift. I used the factory slots on the bottom of the bumper. It worked great!
    Blazin' in Flagstaff
  6. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    I always try to lift under the frame on the front. You can easily bend your bumper if you still have the thin stock chrome one. Be carefull because it doesn't take much to push the jack over no matter where your lifting from.
  7. Brady
    Brady 1/2 ton status
    May 6, 2000
    628
    Parachute,Co
    I try to use under the frame on stock bumpers.If your changing a tire or just lifting it to get under easier,I would use a floor jack,much easier and safer.Just use jack stands when its up.I try to use the hilift for trail recoverys only.Makes a great winch.Once took three hilifts to get my old sub out of a deep rut 2 on the rear bumper and one for a winch.Brady
