Hi-Lift jack's
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fredd, Oct 26, 2000.
  1. fredd
    fredd 1/2 ton status
    127
    Madison, Alabama, US
    Hi-Lift jack\'s
    In most 4x4 related magazines, you find these jacks for $49 up to $69.
    Check your local "Tractor Supply Company" store, they have them for $41.
    fredd
    4x4 Armor for your K5
    http://coloradok5.com/vendors/sec.html
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: Hi-Lift jack\'s
    10-4, yes I have also noticed this. PLus, check out PIerce, they have good deals also!
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Re: Hi-Lift jack\'s
    Northern Hydraulics also has good deals on them. I got the 60" jack for less than $50. Also check the specs. Most of the time the more expensive price is for the all cast jack.
    Jim '80 GMC.
    It's a Wheelbase thing, You're Jeep wouldn't understand!
    http://www.bigjbear.coloradok5.com
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Re: Hi-Lift jack\'s
    Yes, and the all cast jack is the one you want/NEED!!
    I had the POS other one and it failed on me!
    The ALL cast one with a black handel has NEVER failed on me!
    my .25c
    http://www.burt4x4.coloradok5.com
  5. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Re: Hi-Lift jack\'s
    Burt4x4, Which parts aren't cast, that would fail? Not sure which type I have, It's a Hi-Lift HL-484.
    <font color=blue>Maverick</font color=blue> <font color=red>CH 4 or 35</font color=red>
  6. bigjbear
    Feb 18, 2000
    13,967
    448
    Marietta GA
    Re: Hi-Lift jack\'s
    The base & the bracket at the top. I think that is it. The weight ratings are the same for both. I have the cast & steel and it has always worked great, on the trail, street, and around the yard and shop. The all cast jack is red and the cast & steel jack is black.
    Jim '80 GMC.
  7. Burt4x4
    6,854
    Re: Hi-Lift jack\'s
    The head pins that climb up the cast ladder is much smother and dependable. once on the trail I couldn't get the steel/cast one to decend or lower so a buddy had to whip his out to get mine out from under the rig. turns out the climbing part bent [​IMG]. So chucked it and got the all cast one with the black handle.
    The SEC rear bumper carrier pic has the cheaper HighLift style bolted to it! Go to the venders page on the new styles section to see the style that failed for me.....
  8. fredd
    127
  9. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Re: Hi-Lift jack\'s
    Got it. Thanks guys.
  10. fredd
    127
    Re: Hi-Lift jack\'s
    For Burt4x4,
    You are correct, in the pictures is the cast/steel Hi-Lift jack, model HL-484.
    This is the jack I use as jig in the bumper manufacturing.
    Actually, I have 3 Hi-Lift jacks, 48" cast/steel and 48" cast/cast and the 60" cast/cast.
    fredd
