Hi-lift points
Discussion in 'The Garage' started by pismorat, May 31, 2003.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    My truck has Smittybuilt 3" tube bumpers front and rear. I can easily put the hi-lift jack under my trailer hitch out back, but I have no real points up front to put it under. The bumper metal is about 3/16" thick, but I do not think it will hold the wieght of the truck. Suggestions? /forums/images/graemlins/truck.gif
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Get one of the 'Cut-V' front bumpers. They have shackles built into them. Put the Hi-Lift thru the shackle loop & yer good to go. Up that is.
  3. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    Another good place to use the high lift is any of the four wheels. Place it in the upper part of the rim and back the foot off maybe an inch out of plumb. Works great when you want to put rocks or something under the wheel.
  4. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Thought I seen someone use a tow strap or maybe a custom strap that was hooked up around the tire and done the high-lift jack from a shackle like that?
  5. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    carry a piece of wood with you. about 12" long, and maybe 2"x 4". put the wood between the jack and bumper, you might even cut out a groove the length of the board to fit on your bumper, that'll help keep it from slipping off of the bumper. the board will spread out the pressure on the bumper to help keep it from bending or dinging it.
