Hi-lift rebuild kit???
Discussion in 'The Lounge' started by chevyfumes, May 20, 2006.
  1. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Is this a really simple thing to do, I don't wheel and the 2 times I've used it, once when Rene needed it and once a few months ago to help unstuck some dingdong. The problem is, it will jack up but not want to lower, and the last time I used it it had so much weight on it, it damn near ripped my arm off when it did click.I had to tell the guy I was helping to keep his head outta the way 4 or 5 times, but when he saw that, the light bulb came on.Bottom line is I need to fix this thing, it's way too dangerous like this...:doah:
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I smell tech in this post...............
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,393
    E-town baby!
    Most hi-lift problems i've had have been caused by rust and disuse. Hose it down with some penetrant, then lube all the moving bits and it should work good as new. The rebuild kit comes with new pins, springs and the other small bits IIRC...but if you haven't hardly used it you don't need any of that.
    If you're dead set on rebuilding it a good pin punch will really help.
    Rene
  4. chevyfumes
    Feb 24, 2000
    38,584
    266
    Ahhhhh bullsh!t,I had a drink in my hand at all times....:p:
    Thanks Rene...
  5. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Paint it pink!
  6. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Definatly as lubrication problem......... If it is ripping your arm off...... You need some lube and stroke it slower.
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    They miraculously start working if you take them wheeling !!
  8. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    He has been here he forgot that there was a garage. You can get kit for about $15 from anyone that sells the jacks, but those are usually meant for jacks with worn out parts....
  9. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    This could possibly be a phenomenal sig.....
  10. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    Ya know, I was gonna post in here a new thread about "Fumes, I thought of you" ... but this is possibly even funnier.
    See, I saw this sig that said
    Which has Fumes written all over. And you will soon find out that if your lack of lube is ripping your arm off, your goat will be FURIOUS!
    -- A
  11. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    hahaha that made me laugh, that same thing happened to me
  12. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you know fumes a new hi-lift = 2 bottles of booze
    soo looks like you got some figurin to do.:)
  13. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    PB Blaster every time you use it.
  14. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    If the jack is stored outside of the vehicle, DON'T use any kind of lubricant other than graphite. All spray types will attract dirt and keep it there. If on the trail and it doesn't work - I know you're gonna freak over this - but pour water on it.
