HI-LIFT????
Discussion in 'The Garage' started by 85mudblazin, Mar 31, 2004.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Does anyone use a hi-lift?? I dont really want to pay the money for a winch and I was thinking about getting a hi-lift, does anyone use it. Any feedback would be appreciated. /forums/images/graemlins/k5.gif
  2. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    A hi-lift jack? It'd be better to invest in a winch too, a jack will help, but when your stuck in deep mud or rocks, you will need a winch, or skills.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    A hi lift is great as used as a jack or ramp or prybar, but a winch, no, not unless you plan to go 3 feet and then drive out
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    by the time you buy enough grade chain to reach anything, you would have been better off buying a winch. a towstrap and a high lift is worthless because of all the stretch. a hilift is a good recovery tool to have, but nowhere near replacement for a winch in most situations.
  5. grd2go
    grd2go Registered Member
    Mar 28, 2004
    55
    Anchorage Ak
    a winch is always nice to have but a high lift is a must when youre winch dosnt reach nothing solid in the winter here in alaska you dont get to use one of those neat anchors that work in the dirt and mud but a good old highlift jack will save youre ass.. /forums/images/graemlins/crewcab.gif
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You need a hi-lift like you need tow points. /forums/images/graemlins/grin.gif As for using it as a winch, yeah it works in an emergency. It is a humbling experience to say the least... /forums/images/graemlins/grin.gif
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I would tow another vehicle behind me before I will use a hi-lift as a winch. Look into some of the new come-alongs on the market, the more-power-puller is the best I have seen around as a hand operated recovery device. It is similar to a come-along but feeds the cable through the body and out the other side, thus has no power reduction due to cable build up on a drum. You can also winch continually for the 60 feet of cable they give you.
  8. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    If paying for something as essential as a hi-lift jack is a problem for you, maybe you need to take up a new hobby. A hi-lift is cheap compared to how much money this hobby will suck out of you. I just spent enough money on my Blazer to buy eighteen $65.00 hi-lift jacks just to put in a 205 transfer case that I already owned. $175.00 to replace cracked t-case adapter, $175.00 for the non bearing collar, $45.00 for the seal kit to freshen up the 205, $75.00 to remove the t-case and find out that the transmission case is broke and then have the transmission removed(and that was a deal from my friends a Desert Rat in Mesa), $330.00 to have the transmission case swapped into another case that I already owned(including install, and a used crossmember).
    The point is this is not a cheap hobby, but a hi-lift jack is cheap, and necessary for wheeling.
    Later,
    Allan Greenblazer
  9. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    A Highlift can get you out of som sticky situations. I dont own a winch (but need one), its on the list. The Highlift is essential, I did use mins as a winch once when I lost 4wd and slid into a rock and winched my truck sideways 3-4 feet tp get off the rock, couldnt even imagine trying to do that more than 5-6 feet PIA. Get a Highlift, then save and get the winch later.
  10. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I agree a hi-lift is a must have. It will work as a winch, but you will be doing most of the work. I have a winch and a 60" hi-lift along with a come-along in my truck all of the time.
