Hi lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mr. Jimmy, Apr 26, 2002.
  1. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I need a jack for my jimmy, truck has been lifted 6 inches with 35 inch tires. Who has used a hi lift jack and have you been satisfied with using it on a full size vehicle with stock bumpers?
  2. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
  3. keeferk5
    keeferk5 Registered Member
    Sep 9, 2001
    54
    northern illinois
    I have one in both my Jeep and my K5. I would not even think of leaving home with out it.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Might want to go with the 60" over the 48".
  5. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    After installing my 3" lift with 33's I couldn't even get my rig off the groung with the bumper attachment, you definately need the 60"....
  6. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    where on the stock bumpers do yall put the hi lift jack with out any type of bumper attackment? it seems like it would bend the bumper in some places.
    can someone help me out here
  7. Grim-Reaper
    7,385
    Atlanta
    48 inch is fine. Get a choker chain and chain the axle to the frame before jacking. MUCH safer only having to jack the truck 10 inches verses 40 inches. Just be careful of Brake lines with the chain.
  8. Grim-Reaper
    7,385
    Atlanta
    On a stock bumper (at least through 80) there is a small cut out just below where the frame horn is. THat's is where I jack my 79. HiLift also sells a hook that can be attached to the jack and is made to work with stock style stamped bumpers.
  9. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have the "hook" attachment for the stock bumper's...Work's great! I think it cost me $20.
  10. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Hey Grim, That chain to the axel tip is AWSOME!!!!!!! I agree that when you get the HighLift tward the top the rig is very tippy so make sure you have some buddys pushing on the rig the opposite way it wants to tip/lean. Get that tire on quick and NEVER go under your rig with just a HighLift supporting the weight!!!!
  11. Anteak
    Anteak 1/2 ton status
    Nov 7, 2001
    105
    Hemet, Ca.
    How does the Hi Lift work on Smitty Built Tube Bumpers???
    73 Blazer So. Ca.
    SoCalBigDawgs
  12. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I've got a 60" Hi Lift and it works great.
  13. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    ditto on the chain tip grim!!!!! As my rig has got more and more travel capability, it seems that jacking it up to work on it is more and more of a PITA. I'm gonna have to try out that axle/frame chain trick...
    J
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    Same here thanks Grim!/forums/images/icons/cool.gif
  15. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Just my $.02. Hi-lift jacks ARE NOT intended to lift your truck to change a tire. READ THE DIRECTIONS it tells you that it is not designed to stabilize a load. Hi-lift jacks do come in handy and are a must in every truck IMO. I would however also keep a bottle jack (of the proper size for your truck) in the truck for changing tires.
  16. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hehe, yeah. If I jack from the frame, I can no longer get my tires off the ground even with a 64" Hi Lift! I either strap or chain the axle to the frame, or I use a floor/bottle jack under the axle.
