hi/low beam help
Discussion in 'The Garage' started by xstream70, Oct 8, 2005.
  1. xstream70
    xstream70 Newbie
    Sep 11, 2005
    honeoye falls n.y
    4 light system (right now all on or all off ) put in new switch , new lights ,harness looks fine????????????????? any help please
    :confused:
  2. neubanksc5
    neubanksc5 1/2 ton status
    May 13, 2005
    281
    Concord,CA
    what year truck we talking about here? I had a 74 with an 87 4-headlight grill that had the same problem. The terminals of the high beam footswitch were corroded a bit, worked fine after i cleaned it up.
    what switch did you replace? if you replaced the headlight switch, i'd say check your high beam/dimmer switch whether it be the foot switch or on the column
  3. xstream70
    xstream70 Newbie
    Sep 11, 2005
    honeoye falls n.y
    well I found the problem ,I found out the low beams will light up even if they are bad,I put 2 other lows in and now it works fine. :D but thanks neubanksc5
