hi pinion.......
Discussion in 'OffRoad Design' started by hi pinion, Dec 19, 2003.
  1. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    hey everybody.....here we go... i have a stock 85 blazer,i have a hi pinion d 60 with 513s built by boyce and an arb.i also have a 14 bolt on the way.i like the looks of the 4 in flip (ord)..i want to run 38 in or 39.5 in tires with no trimming or minimal . what will clear these tires?in the rear i will install the flip,but what size spring will clear? for the front, i dont want to run a set a 10 springs and be done with it,i would probobly end up with a super stiff ride. what can be done here?extended shackles for the front mabey? any suggestions are welcome and the sky is the limit, so input please...........YOURS TRULY HI PINION /forums/images/graemlins/cool.gif P.S. this truck will be given to my son,Jeremy Austin ,as for a 16th birthday present /forums/images/graemlins/thumb.gif
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    the front, extended shackles cause trouble and only give like an inch of lift. Dropping the spring hangers is the only option for big lift and not stiff front springs, well not the only option but the only one seems like up your alley. I'd say run, a Zero rate up front, 8" lift springs, and the ORD shackles, Give you a little more than 9.5" of lift with 8" springs.
  3. hi pinion
    Sep 25, 2003
    5,354
    OK cool. what would be some other options?10 inch lift will fit 38s or 39.s?HP /forums/images/graemlins/thumb.gif
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I'd think 38s would fit with 8" of lift. Other options are 3 and 4 link front suspensions but for a road driven vehicle its not a real option.
  5. hi pinion
    Sep 25, 2003
    5,354
    Alright.i guess it all boils down to how soft of a spring i get for the front right?do they make a kit to drop the hangers? Im not ready for crossover steering just yet,ill wait for that.HP
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    No one makes a drop hanger kit, it would have to be custom stuff.
  7. hi pinion
    Sep 25, 2003
    5,354
    ok, do you know of anyone who has done this?HP
  8. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    Some advice:
    Go ahead and trim the fenders, they're cheap to replace if you decide you don't want it trimmed and they allow a much lower ride height which creates a lot more stable and drivable vehicle.
    Plan on a bit shorter suspension, based on trimming the fenders out. This makes your steering correction a lot easier and much more effective, along with leaving you with much better drivetrain angles, mostly for the rear driveshaft.
    I'm not sure what tires you're looking to run but it sounds like you're going to want a decent radial tire which brings you to a 37" tire, or the PJ or swamper 38".
    Consider a body lift, we're really fond of the 1", and that does help you out with tire clearance with pretty minor problems otherwise.
    I hate to push a cookie cutter K5 but the one we worked on for David Kennedy at Petersen's 4WOR (ultimate adventure K5) would be a good one to copy. It worked really well as a street driver and was a nice offroad rig too.
    My recipe for you? 6" suspension, 1" body lift, 37 or 38" tires and trim the fenders to fit. The crossover steering, axle gearing, etc is all a different subject but this would be my recommendation for the lift setup.
  9. hi pinion
    Sep 25, 2003
    5,354
    /forums/images/graemlins/cool.gifHP
  10. marv_springer
    marv_springer 1/2 ton status
    Aug 3, 2001
    2,781
    Mesa, Arizona
    Nice gift /forums/images/graemlins/eek.gif!
    But based on my experiences w/ teenagers.... I'd recommend a rollcage /forums/images/graemlins/laugh.gif...
    Marv
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Marv
    Marv, he said SON.... not daughters...... /forums/images/graemlins/thumb.gif
    Grant
    PS, as for the subject at hand, i have to agree with both Stephen and Marv.
    Grant
  12. hi pinion
    Sep 25, 2003
    5,354
    thank you steven for your feed back its nice to talk with heavy hitters that know what there talking about.i will post pics when im done(whenever that may be)to show progress.Any information is always usefull.YOURS TRULY HI PINION /forums/images/graemlins/cool.gif
