Hi speed vibes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Flyinhi86, Jun 18, 2001.
  1. Flyinhi86
    Flyinhi86 Registered Member
    Mar 31, 2001
    51
    Ft McMurray, AB, Canada
    Sometimes from stop I will get a shimmy or bit of a shake, this also happens when I get up into the 60 MPH range. I am running 350, 35" tires w 4" lift. Would this be the driveshaft articulation or angle. Its seems to be allright any other time and I also put the spacers in the transfercase mount. What is this problem?
  2. rich'90
    rich'90 1/2 ton status
    Feb 27, 2000
    159
    Savannah, GA
    Did you balance the tires on or off of the vehicle? From what I understand this can make a difference also, someone else might know a little more about it than me.
    Good luck!
    Go heavy or Go home[​IMG]
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    try taking your tires in and have them ballanced(sp?) whenever mine starts to vibrate some i take it in and have them rebalenced and rotated and it goes away
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  4. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    you could also have the alignment checked. with the bigger tires i believe a smaller misallignment will be noticed more
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    What kind of tires are you running? you also might want to fill out your profile!
    <A target="_blank" HREF=http://community.webshots.com/user/vwryda>http://community.webshots.com/user/vwryda</A>
