hi steer, hydo assist, death wobble?
Discussion in 'The Garage' started by camok5, Jun 6, 2005.
  1. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    So I have the common death wobble problem with my dana 60 crossover and was woundering if hi steer would make things worse or better and is hi steer alot harder on king pins for a daily driver? Also would like to know what companies make a good hydo assist steering kit other than WTO(redneck ram)?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I don't think it matters if you have Hi steer or not... it will wobble the same either way.
    I got my hydro kit from www.rocklogic.com and it seems to work well.
  3. PeteH
    PeteH 1/2 ton status
    Mar 26, 2003
    498
    San Jose
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    You need to rebuild your kingpins.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    As mentioned.....High-Steer or Hydro-Assist are NOT the source of death wobble. It's typically caused by worn kingpins, bushings or the kingpin spring losing spring pressure.
    High steer has made no noticeable difference in death wobble for me (ORD version) but the hydro assist I installed (1.5" WTO version) did help to "mask" the death wobble.... the operative word there is MASK. It doesn't really cure death wobble, it simply makes it harder to notice. Even with hydro I can induce bad death wobble if I turn the wheel sharply at low speeds.
  6. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I already replaced all the king pin parts and I am running dual stabalizers and just about every steering part is new but would still like to know if hi steer will wear out the kings pins faster with a daily driver or if there are any other draw backs? I have just about givin up trying to get rid of the death wobble and will most likely try to "mask" it with hydo assist. One more question, does anyone know if putting a panhard on the front would help with the death wobble because I already plan on putting one on to help with the bump steer?
  7. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I wouldn't think a panhard would effect death wobble, but maybe somebody else will chime in.
    Have you tried shimming the upper kingpin springs with some washers? A lot of people, including myself, used this to correct death wobble issues. The stock springs were never designed to handle big tires!
  8. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Shimming is my next step, what thickness washers should I use and can this cause any problems?
  9. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Anyone? I would like to know before I do it. :confused:
  10. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    try 3/16ths total first, should do the trick. you can always add more washers
  11. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    So i put 1/4'' washers in and now my blazer tracks really bad and is a little scary to drive on the freeway, any other ideas or should I try and use a less thick washer? :confused:
  12. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    There is absolutely no reason that shimming the upper king pin springs should cause these issues.
    Where exactly did you put the washers???
    Did you make sure the upper caps are still fully seated against the knuckle?
    Kinda' sounds like the steering arm is loose.
  13. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I put the washers in between the nylon bushing and the spring, the caps are tight and the steering arm is fine. Does anyone else have any ideas? The problem is when I turn the steering wheel a little while driving it doesnt want to return straight as easly and it seems like the steering is actually to tight.
  14. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    You usually put the washers on top of the spring, but not sure if it makes a difference or not. Based on your latest description it sounds like something may be binding (assuming the washers are the only thing you've changed). I would pull the uppers apart and make sure everything still looks okay, and then try a little smaller spacer.
  15. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    Thats my next move, I dont see how the washer being on top would change anything but I have been wrong before. :D
  16. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Don't mean to hijack the thread, but what should I look for when I tear down my D60 to see how far i should go into the kingpin rebuild? Seems like a full rebuild is a pita, but if necissay I'll do it. I'm deffinately gonna replace the bushings and springs just for the sake of, but that's fairly simple.
  17. camok5
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I would only replace everything if the kingpins themselves looked worn or pitted.
  18. Clod_King
    Clod_King 1/2 ton status
    Jun 7, 2005
    1,094
    Grimsby Ontario
    what is death wobble? I have never experienced this before? and is there a way to cure it?
