Hi steer or just crossover
Discussion in 'The Garage' started by crazyrc, Sep 6, 2003.
  1. crazyrc
    crazyrc 1/2 ton status
    Jan 20, 2003
    106
    Northern Alberta, Canada
    I'm planning on a doing a crossover setup with a hydaulic assist in the near future. Does it take much more work or $$$ to do hi steer at the same time. I'm sitting at 8" of lift. Other than different arms what other parts do you need for the hi steer.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Any particular reason you're going to do hi-steer? Do you rock crawl? A lot of guys choose the beefy tie rod approach with sucess.
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    My opinions:
    1. 8" lift is too much. If it's a show truck, you should be asking where to buy chrome pitman arms. If it's not a show truck, drop it some.
    2. I'd rather have my beefy rockrod hit something than my Dana 60.
    3. Hi-Steer is problematic for daily drivers.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Personally I feel that the D60 knuckles are a little weak to be doing high steer on with 40"+ tires and hydro assist. I do tend to worry about breakage more than some other people do. I put a Rockstomper tie rod on mine with regular crossover, the tie rod is one beefy unit so I think I'll have a real hard time bending it. Hydro assist was much easier to do and I don't have to worry as much about breaking a knuckle. </font>
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My opinions:
    Somehow I don't think you're much of a mudder then. Where I go, getting your frame off the ground has a serious benefit. This can be done with more than tires. I am considering going up to an 8-10" suspension lift and getting rid of my body lift.
    Then again, when you run really big tires, there are only three options. Lift sky high and don't cut, lift almost sky high and still cut, just don't go insane (my personal choice) and hardly lift at all, and hack the hell out of your truck.
    Personally, I think hacking your truck apart for what I do is stupid, but the way you build your truck is your business.
    I'm happily at 9" of lift thank you.
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I just use the beefy tie rod that ORD sells. He recommended that if I was going hydro to just use the standard tie rod location. Trust me ORD HD tierod will take some serious abuse and not bend. /forums/images/graemlins/thumb.gif
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Somehow I don't think you're much of a mudder then...I'm happily at 9" of lift
    My opinion is that that's still too high.
    There is no reason for the CG to be that high.
    Cut the fenders some, to fit your tires. If you're really a mudder, then you won't need to cut as much because articulation is not a big concern.
    As I'm sure you know, 8" leaf springs and higher ride terrible. I am still interested in a decent riding truck.
    About my name - I picked it some time ago when all that I knew was mud. I have since figured out that a well-rounded truck is more to my liking.
    And maybe I've been out of the loop for a bit, but aren't you supposed to be over in Iraq? LOL
    Take it easy.
  8. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Not to hijack, but why is hi-steer problematic for street driven vehicles? I'm kinda curious, as I just put the ORD Hi-steer arms on my axle. Is it something with the design of the arms themselves? Or just the geometry of hi-steer in general? I'll be using a beefy tie rod, and hydro assist.
  9. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> In the past there were problems with hi-steer arms having really flubbed up Ackerman angle, but I think that Stephen built his arms to provide an acceptable Ackerman angle, so you shouldn't have a problem with it. </font>
  10. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Personally I think it's your choice..... High steering is nice because you no longer need to worry about the tierod "ENDS" being busted.... I would still go with a beefy tierod even if you lift it.... Bigger tires mean bigger stresses on stock parts and the tierod Chevy put on these isn't stout at all... The biggest week link in the rod is the material it's made out of, it's solid.... Once you bend a solid pice of material, it has little to know flex, therefor it will stay bent and not flex back to straight... That is why every aftermarket rod is made with tube and not solid material!
    About highsteer and stock knuckles... I've also heared of the "Problomatic busted D60 knuckle" theory... I call it a theory because unless you are wheeling the dog snot out of it with larger than 40" tires and busting it against the rocks with a hydro ram.... I wouldn't worry about it! It takes alot of forces to sheer the top af a D60 knuckle off!
    You can go the beefy tierod way and try and use it as a bumper for sharp rocks, but they're still going to find your cover one way or the other, so You need to beef it up anyways! Hydro is uneffected weather the tierod is in stock location or in the top location! Personally, my concern is the tirod ends more than the rod itself...
    Here is what I have done, use it if you may, but It's what I've come up with the most beefy setup until I can bullet proof the knuckles...(Please keep in mind that I plan on beating on this truck pretty severely...)
    First, I suggest Sky manufacturing for the arms... They are the only arms I've ever seen that are built beefy enough to take a severe load and won't put that load on my wallet!
    I then ordered a beefy draglink from Rockstomper with the sleeved rod and the beefy ends..... I put a 2wd box on that will be tapped later for hydro and a Superlift drop pitman arm... I decided to make my own tirod since I felt I could build one for cheaper and beefier than I could buy one from Rockstomper! I simply took the dimensions from their site as to what interior size the tubing was and purchased some DOM 5/16th wall tubing and some 1/4 wall tubing to slide over the 5/16th... My rod is about 2.5" thick and sleeved to allow the material to flex.... I perposly put the thinner wall tubing around the thicker wall to increase strength but to also allow the thinner wall to stretch over the thicker wall! It has a very minumal deflection, but It sure as hell won't bend neather! I mounted this atop the steering arms and springs and out of harms way... I shouldn't have to worry about replacing these ends unless they just plain wear out! PLUS, all my ends are ES2334Rs... I only have to keep 1 type of spare in the truck and it covers all four ends!
    Now that my rod is out of the way, I had to beef the only other weak section of the front of the axle, the cover! I'm having a set of diff covers made that have 5/16th steel welded over the front, 3/4s of the bottom diff like this...
    This should make the cover beefier than the tubes and I know none of us are worried about bending or breaking an axle tube! From what I hear they make for some awsome protection for my 5:13 gears and Detriot! Eventually I might truss the axle, but that will be a ways out! If I do run into a knuckle issue, I will replace the ends with these:
    But that's a long ways out.... If I break a stock one, I'm driving wrong!
    This basically bullet proofs my front end! Once I go Hydro, My ram will be up and out of harms way! I won't have to worry about tearing anything up down there! Again, This is how I did mine and has no bearing on what other do to their's! /forums/images/graemlins/thumb.gif
