Hi-steer w/zero rate and axle moved 1.5" forward
Discussion in 'The Garage' started by cegusman, Dec 18, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Hi-steer w/zero rate and axle moved 1.5\" forward
    I am about to swap in my dana 60 but would like to do hi steer. I have 4" lift springs, plus a zero rate moving the axle 1.5" forward and using a sky-manufacturing steering arm for my cross-over. If I get another sky arm for the drivers side to run high steer, will the tie rod clear the leaf springs?
  2. CK5
    May 19, 1999
    21,627
    704
    CO
    Re: Hi-steer w/zero rate and axle moved 1.5\" forward
    I think you might be OK with tierod to spring clearance but your tierod would most likely contact your pitman arm.
  3. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Damn, didn't think of that. Guess I will wait until the 60 is under there and see what it would look like.
  4. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    /forums/images/graemlins/cool.gifI have that set up and have no clearance issues. /forums/images/graemlins/grin.gif
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Cool /forums/images/graemlins/thumb.gif That is good news then
