Hi-torque starter?
Discussion in 'The Garage' started by pismorat, Sep 3, 2006.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    My dad has a '60 Vette and its having the typical Chevy soleniod issue. We put a shield on it and it still won't start when its hot. What is the best type (price and quality) of hi-torque starter to get so the smaller body will keep it further away from the manifolds...plus have better starting power? I am also going to get one and put it on my truck. Thanks.
  2. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    The summit ones seem to be a popular choice.... Think they run $150 to $200..
    A remote start solenoid will help the most, but I'd start with the mini... Never hurts to have a badass starter under there..
  3. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yeah, FURD style solenoid, works fantastic.
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Do the solenoid first. You most likely not need the mini starter once you do that unless your running extremely high compression.
  5. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Not to be an argumentative d*ck or anything but your also adding a potentially failing component to a system...
    I'm not objecting to it, heck, most boats I work on have multiple slave solenoids. But I do try to keep in mind that your adding more connections to fail, plus the solenoid itself... And with the quality of wiring work I see most people do, it's an issue sooner, rather than later...
    Also I'll take a quality mini over a full size starter anyday.. high compression or not.. You couldn't kill the Tilton i had in my Chevelle...
