HI-vol oil pump and 20psi?
Discussion in 'The Garage' started by bigarmzz, Sep 7, 2006.
  1. bigarmzz
    bigarmzz 1/2 ton status
    Feb 21, 2005
    184
    elkins, west virginia
    i bought a melling hi vol oil pump for my 87 tbi, oil pressure is through the roof at start up, but after it warms up, it only has like 20psi...???:confused:
    i got mechanical gauges, so i know this pressure to be accurate...any ideas?
    (just hoping i dont have spun bearings or anything):( the motor runs like a power house
    i did a compression check on the cylinders as i was curious, here's the compression:
    8-155 1-160
    6-160 3-175
    4-175 5-175
    2-150 7-175
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Was the oil pump the only thing that changed on the engine? If so, what pressure was the engine running with the old pump, under the same conditions? How many miles are on the engine?
  3. bigarmzz
    Feb 21, 2005
    184
    yeah, stock motor
    before the hi vol install, it was reading (with the stock gauges) around maybe 12-15psi when warm, thats why i wanted the hi vol setup....but now its not reading that much more than it was before..... for some reason
    motor's only got (supposedly:rolleyes: ) around 80k on it, which may be, cause it has good compression of all cylinders, and is real clean inside
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    What's the oil pressure at idle and with RPM's? 20 PSI at idle is not too bad. If you want more pressure you may need to step up oil viscosity. Internal bearing clearances could also be loose, thus causing a drop in pressure.
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You wanted a high pressure, not a high volume. When warm I have like 50psi with 15w-30. At rpm, my guage doesnt go high enough.
  6. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    I have the same pump on mine at idle warm it is 20 but as soon as it comes off idle it jumps to 50 that is with delo 15w-40. Seems nomal to me if you want more pressure get a diffrent pump.
  7. bigarmzz
    Feb 21, 2005
    184
    yep, thats what i was wanting:rolleyes:
  8. sweetk30
    Nov 1, 2004
    25,534
    530
    horseheads , ny 14845
    10lbs per 1k rpm. and idel is around 750-850 rpm so around 10-15 psi is perfect. did you get the hardened and pined shaft to go with the hv pump?
    and if you have 20 at idel warm wow thats great.
    oil is thick at cold = much more pressure
    oil is thinner at temp = less pressure
    try sucking a thick milk shake threw straw and then suck water threw same straw. same basic idea. flows better when warm.
    why do you need so much oil volume and pressure. you need to make sure you dont starve the pick up with these pumps . comon problem under 4x4 conditions as thay suck a lot more oil. and did you tack weld the pick up in the pump?
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Hi volume only increases the amount of oil it moves not the pressure of the oil. The only thing that affects oil pressure are bearing to crank clearances and cam to bearing clearances and also pressure relief spring in the oil pump. My rig has 231K on the original engine (never been apart yet) and cold it pegs the gauge at 60 plus psi and running temp it sits right between 55-60 psi.
  10. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    My stock motor with 160,000 miles on it gave 30psi, hot, cold, idle or 4000rpm. When I rebuilt it I put a new oil pump in, can't remember the make, and now it is pegged out when cold, even at idle, but when hot gives 20psi at idle and around 45 or so at higher revs. That's with 5w30 mineral oil. (which I've always used)
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    The Melling pump in mine behaves similarly. Its got 700 miles on a new crank/crank bearings. At start up it pegs the gauge, once warm, at idle, around 30.
