Hi volume water pump
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JTB, Dec 5, 2000.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    Do hi-volume water pumps really work? I dont want to have to worry about heating up. Please list a supplier if you have been happy with yours. Thanks
    Jeff
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Unless you towing , generating some real serious horsepower or running some kind of exotic fuel, your stock water pump should be just fine. If you are having cooling problems. A larger radiator is a better fix. More flow through a small or plugged radiator wont cool any better.
    If you get a high volume pump you should have a large radiator and high volume thermostat to get all the cooling you payed for.
    http://summitracing.com carries them for about 60.00 bucks
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    look into a cop car water pump, the impellers are made differently bercause cop cars idle a lot and the motors run always in all types of weather. PS, thunder is right on point with his advice.......js
