hi
Discussion in 'The Garage' started by socalsnake, Feb 4, 2006.
  1. socalsnake
    socalsnake 1/2 ton status
    Sep 17, 2005
    121
    CA
    why do people weld there axles to there gears to there diff what are the pros an cons and what are the bad about it
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    What?? That is very confusing too me.
  3. socalsnake
    Sep 17, 2005
    121
    CA
    why do people weld axles shaft to there spider gears an is there any pro's an con's about it what does it do to the rigs
  4. readymix
    May 30, 2004
    6,706
    26
    That sounds retarded. If you were to weld your axles shafts to the spiders, then you could not service your diff at all without a torch or plasma....
    Other than that I see no reason to do it
  5. socalsnake
    Sep 17, 2005
    121
    CA
    ok can u destroy other things an wear and tears parts an for example
  6. readymix
    May 30, 2004
    6,706
    26
    No, the truck would be fine and run as designed if you welded the axle shafts to the spider gears...but you would never get the shafts out again
  7. socalsnake
    Sep 17, 2005
    121
    CA
    but dont u have a problem by steerin
  8. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    i assume he's talking about welded spiders... :confused:
    it'd be easier to know if he used a little punctuation... question marks and periods are your friend... :wink1:
  9. socalsnake
    Sep 17, 2005
    121
    CA
    what actually happen was when i went to gorman my drive shaft broke right after i put it in 4 wheel drive and it broke then when i went to my mechanics house from drivin it front wheel only the u joint off the front right pasenger side of the wheel broke then my mechanic open the pumpkin an realize the 2 inner axles are welded together to the spider gears and he said tat both diff are the same since actin the same way now would this problem cause these kind of carnage i dunno what to do
  10. socalsnake
    Sep 17, 2005
    121
    CA
    also found out before it broke i was having trouble steering before it broke
  11. socalsnake
    Sep 17, 2005
    121
    CA
    i also my rig is a dd
  12. ryoken
    Jun 13, 2003
    29,622
    1,374
    Jersey Shore
    well, it sounds like you have a Lincoln Locker.. the spider gears welded.
    and yes, this can definitely add stress to all moving parts in a front differential. they've been known to grenade..
    and yes, it will more than likely be difficult to steer, especially with near-stock steering components... certainly not a very street friendly setup...
    here's a threads on it...
    http://coloradok5.com/forums/showthread.php?t=156630&highlight=lincoln+locker
  13. socalsnake
    Sep 17, 2005
    121
    CA
    what is a Lincoln Locker? is it good cuz it doesnt have a ball or anythin in the middle is it why i busted out my axle ujoint an the same with the rear driveshaft?
  14. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Welded with a LINCOLN welder. If i were you, id find another axle and swap it. Less bolts to undo. Make sure gears match. As for your driveshaft, get a new one from a driveline shop.
  15. socalsnake
    Sep 17, 2005
    121
    CA
    will it eventually do it again?
  16. socalsnake
    Sep 17, 2005
    121
    CA
  17. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    You need to do some reading. I'll post some titles with pics, it'll take about an hour.
    Read these books before spending any more time and money. There are more books, but these will start you on the right track. First one is ISBN 0-7603-0798-9, ~$25. Number two is ISBN 0-8376-0157-6, ~$35.
  18. socalsnake
    Sep 17, 2005
    121
    CA
    ok thanx so its not all that bad? does it break all the time i have 38.5 tires
  19. socalsnake
    Sep 17, 2005
    121
    CA
    where would i get these books?
  20. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :confused: Amazon, B. Dalton, Barnes & Noble; any large bookstore. Again, stop all spending until you've read these.
