HID lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tecton, May 31, 2003.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    do they make replacement lamps for 86k5 with single headlights?
  2. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    Yep .. I have Bosch lights, but look into Hella as well. I'm sure there are more, but those two pop into my head first
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Bosch has a kit for single headlight setups. It converts your sealed beam system to an H4 halogen system.
    If you're really serious about going to full HID you'd better be erady to spend a whack of cash. The H4 system is like a poor man's HID.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The HID setups that I've seen cost around $500 PER BULB! /forums/images/graemlins/eek.gif :insert_little_smiley_passing_out: /forums/images/graemlins/wink.gif
    Here's a link to some aftermarket kits: http://www.sylvania.com/xenarc/prodinfo.htm
  5. Chris_T
    Mar 17, 2001
    718
    Saskatoon, SK
    You can get HID bulbs for the same housings as the H4 conversions, no?
  6. Can Can
    15,552
    136
    Yeah, I think I read that somewhere, but I'm pretty sure that they aren't authentic HID bulbs. IIRC, a true HID system needs a fancy relay/inverter and wiring setup in order to produce the High Intensity light.
  7. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    There has been a few post about this, if you do a search for "headlight relay" you should be able to find it. I did a conversion to CIBIE E spec headlamps with H4 bulbs and its the best daily driver mod i have done. I'll give you a link to a site with more info than you ever wanted to know about head lights. Just a word of caution i originally but in Hella H4 conversions with over wat bulbs, i kept blowing fuses and melted my plugs. so you have to upgrade your wires. i also found the Cibie's have a better beem pattern. You can find the lamps on ebay sometimes. Its not cheap per say but it will make driving at night enjoyable. If you have any questions ask. He is very good about answering any questions, but everything you need to know is on his web page.
    Danial Stern Lighting
    http://lighting.mbz.org/
  8. Grim-Reaper
    7,385
    Atlanta
    On the Hella lights. There are two different H4 light sets. There are the "DOT" approved lights that are better then the Hologen sealed beams and legal.
    There is also some that are "For offroad use only" Those are awsome! I have them and have had them for 15years. When aimed properly the lowbeans are not a problem with other drivers. The high beams are devistating. I ram them with 90/100 watt bulbs. Incredible amount of light. Unfortunatly the higher watt lights don't last nearly as long as the standard 55/60 watt bulbs and the replacement bulds are about $15 verses $8.
  9. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Here's another page with more lighting info...
    Auto Optiks
    I really like the "vehicle lookup" feature, you can find the P/N's for every bulb on your vehicle.
  10. tecton
    Dec 1, 2002
    1,553
    WV
    i dotn mean the real hid...i want blue/white headlights
    mine suck...and i cant get bulbs cause mine are sealed
    i see them all the time in stores...but i dotn know what kind to get
  11. Can Can
    15,552
    136
    Like a bunch of us already said, forget about going with a fancy(yet still crappy) upgraded sealed beam and spend a couple extra bucks on the Bosch or Hella H4 conversion. It's well worth the money, TRUST ME!!!!
  12. rugger03
    May 14, 2000
    829
    around
  13. tecton
    Dec 1, 2002
    1,553
    WV
    whoever wrote that is pretty paranoid /forums/images/graemlins/wink.gif
    i just want my lights to look blue/white...for the cleaner appearence
  14. Ruthven13
    Ruthven13 1/2 ton status
    Mar 10, 2003
    664
    Fair Verona
    I see the Auto Optik conversion is the only one available for the '91 mini quad style lights. I seen to remember that someone said they are worse than the stock lights. Anybody else have any opinions? I had the Hella h4 lights on my last truck, and i theink they were the best things in the world and i want them again!
  15. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    For those that did the Helle H4 conversion..where did you buy the kits? prices?
  16. chevblazk5
    chevblazk5 1/2 ton status Premium Member
    Mar 19, 2002
    257
    Sayreville, NJ
    I got mine from a local speed shop. I paid $100.
  17. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    well you can goto Autozone and pick up their RALLY brand replacement set ups, two big square lamps, and then you install new H4 bulbs in there, looks sweet, but then again 9$ a bulb isnt bad compared to 15$, but to each his own, i might convert over the summer. /forums/images/graemlins/thumb.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  18. tecton
    Dec 1, 2002
    1,553
    WV
    i got me some 16$ replacement lamps...super whites...love them...they light up the underneath of my engine and under the hood...looks really cool
  19. Terminaltsi
    Terminaltsi Registered Member
    Jan 22, 2003
    44
    louisville, KY
    ok, go to www.nopi.com and order the Hella H4 replaxcements. they are around $40 ea. and include new H4 clear bulbs. at teh same time, you can also order some hyperwhite bulbs for them for that clean white look. these work great and give much better light than stock headlights.
    P.S. i have a real HID conversion which i bought back in 99 for my Benz. this is the best headlight system you can get , and now they are cheap as hell ($300) for a set including bulbs and ballasts.
  20. BAJA_BLAZER
    BAJA_BLAZER 1/2 ton status Author
    May 17, 2001
    517
    San Diego, CA
    If you want real HID replacements check out: HID Replacements We run them in the race truck along with 6 Hella HID's on the light bar.
