hidro assist help
Discussion in 'The Garage' started by BADRED73-N-AZ, Jan 25, 2004.
  1. BADRED73-N-AZ
    BADRED73-N-AZ Registered Member
    Jan 26, 2002
    65
    AZ, United States
    having trouble every once and awhile usaly in a tight spot it want turn to the driver side. it is a WTO system. havent had it on very long. I have repeatly bled the system. I also have cooler and large filter on it.
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Try to elaborate more on what your trouble is, though it sounds like at idle your pump isn't provididng the ram with enough fluid.
  3. BADRED73-N-AZ
    Jan 26, 2002
    65
    AZ, United States
    it is not just at idle even if i put it in park and rev it up it takes both hands and hard core force to get it to move. but it only does this some of the time usualy in athight spot
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Did you mod the PS pump?
