HIEM joints/highsteer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jackedjimmy, Sep 16, 2002.
  1. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    Sorry for the double post but....
    At my new job, i can get built axles for my blazer for little $$$, which will speed up the process on the soon to come axle swap. I am planning getting a 14ff with 4.56r&p and a detroit rear and 8lug d44 with an open diff and 4.56s
    I can get the 14ff for around $500 and the d44 for free minus gears and nuckles.
    So i might as well do crossover at the same time right?
    One of the people i work with has a jeep with a GM drivetrain (ofcourse) and made his own steering using i think 1 1/4 inch solid tube drilled and tapped out for heim joints with regular threads one one end and reverse on the other. His draglink he also made out of the same stuff. His tierod is running over the springs via a custom spacer thinggy that is attached to his d44 ends, which allows it to go over the top.
    What i want to do is basically copy this with a bent draglink and a tie rod over the top of the leaf springs. Anyone see any problems with this?
    Sorry for the length.....Any info apreciated
  2. jackedjimmy
    May 18, 2002
    195
    Redmond WA
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Sounds like a sweet job with awesome deals - what company, what do you do?
    About the crossover steering, from your description it sounds like the basic crossover setup. Correct me if I'm wrong. Go back to coloradok5.com's homepage and click on the "technical" link. There you'll find an awesome writeup of how a crossover steering setup was done. Sounds the same to me as what you described - only difference being tie-rod material/design.
  4. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    Its called eastide cusom truck...Kirkland WA
    We do basically anything automotive besides rebuilding trannys,axles. From just a basic tune up to a SFA swap and 1ton swap on a 94' chevy p/u
