High Angel Driveshaft question
Discussion in 'The Garage' started by hidesertwheelin, Mar 25, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    Does anyone know if HAD's slip yoke driveshafts are missing one spline inside the slipyoke? I need to weld up the breather hole inside and was told I need to remove a spline if one isn't already missing.
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I don't have an answer for you but there is no reason for a spline to be missing in this application. The yokes from some two piece drivelines actually have one wide spline so that the two shafts can't be phased incorrectly.
  3. hidesertwheelin
    Nov 13, 2004
    782
    4
    Hesperia, CA
    The reason I ask is I am having a leak out if the slipyoke breather hole. A gut who ones a trans shop on a different board said I need to weld the hole shut, and also remove one of the splines when i do it.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The slip yoke will leak from the hole if the splines are worn out. I would not weld the hole shut either. Give Jesse at HAD a call. He doesn't frequent here as much these days but he will definately help you over the phone.
