high angle 205 brake...
Discussion in 'The Garage' started by 84gmcjimmy, Jul 18, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I can't find it on the page... can anyone give an est. on how far down on the page it is? (example: 1/2 way down) or something so I can look/read about it. Thanks
  2. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    High Angle Driveline isn't in the market of building crap. Of course it works well. It's not cheap (over a grand when you buy the shaft and that at the same time, and you MUST be running his shaft to run the parking brake) but it does work well.
    Jesse rocks. I can't say enough good things about the way his business is operated, and I wish more vendors were like he is.
  4. mcinfantry
    mcinfantry 1/2 ton status
    Dec 2, 2003
    308
    im using it. i sheared the bracket off on the first one, jess took care of me, and now i have no problems. we think it was a metal defect. he said im the only one who has ever done it.
    i have always prefered driveline brakes ever since my first military jeep (m38a1)
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    are you saying it needs a custom shaft built for it, or can I order it, then when I get money for dirveshafts, I can call him up and make me some?
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    his brake uses his flange for the rear CV shaft. you could probably put it on now but it would cost alot more in the long run.
  7. mcinfantry
    Dec 2, 2003
    308
    correct
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I've got one. I love it!
    The driveshaft was an upgrade I was going to do sometime anyways...so that wasn't a huge deal.
    The brake was easy to mount and hook up the cable to (I hooked it up to one of the stock exhaust hangers with a small piece of angle iron with 2 holes drilled in it and one bolt).
    It will hold my truck (trans in N) on just about as steep a hill as the tires will hold on.
    I got the 11 o'clock position. It was the best place I could think of for the cable to hook up to...however I had floor clearance problems. You could either add a boly lift, or use some other clocking...I just jacked up the truck by the middle of the floor /forums/images/graemlins/screwy.gif
  9. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Why would it cost more in the long run? I wouldn't be running it until I have enough money for both shafts... /forums/images/graemlins/dunno.gif
  10. oilburner
    oilburner Registered Member
    Jun 23, 2004
    14
    Montgomery, NY
    I have this EBrake setup installed in my CrewCab, and you DONT need to buy Jess's driveshaft to use it. He supplied me with the yoke for a 1350 ujoint, and I had a new shaft made locally with that yoke. I have had ZERO problems with Jess's parts, as they are real nice quality.
    OILBURNER /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif
  11. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Okay, when I get closer to actually buying it i'll shoot him a email and ask some questions... thanks /forums/images/graemlins/peace.gif
  12. oilburner
    Jun 23, 2004
    14
    Montgomery, NY
    Better than Emailing him - shoot him a phone call 530-877-2875. He is a super nice guy and very helpful.
    /forums/images/graemlins/peace.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/crewcab.gif
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have it on my truck too and I agree that it's a great peice. The only thing that you should be aware of is that Jess provides absolutly NO means of hooking it up, you're on your own for that part.
  14. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    How hard is it to hook up? Does it use the existing brake lever (emergancy brake) or how do I oopererate it? Thanks
  15. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    I ordered the e-brake with my Atlas and I have yet to run it so I have no opinion on how well it performs. To hook it up, my plan is to visit a local bone yard and rape the center console e-brake lever and adapt the cable to work on it. That way it is close by and easier to use while on the trail.
    I have a question about how long the pads will hold up and do I have to buy replacements directly from him or can they be bought at the local auto parts store?
  16. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Hooking up the cable on mine invloved the use of some angle iron, 2 different drill bits, and one bolt with nut and washers /forums/images/graemlins/screwy.gif I used one of the factory exhaust hangers to attach to. I then cut down the threaded rod on the end of the brake cable and hooked it up with a couple compression coil springs over the cable to make it return when released.
    Then pads on mine seem to be holding up well...even with a friend of mine driving 2 blocks with it on /forums/images/graemlins/shame.gif and all the mud I play in hasen't seemed to make any difference either.
  17. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I guess I am the only one who doesnt care for the product. It was pretty expensive and didnt work too great. I talked to Jesse and he took it back. Seems everyone else likes them because he had it sold before he got to credit me back, haha.
    This is not true. You dont need his shaft, OR his flange if you already have one (mine wasnt from HAD). I remember there was 2 differrent sizes, cant remember if it was for the seal or the rotor. /forums/images/graemlins/dunno.gif
  18. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Care to expand on what you didn't like about it?
  19. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It was a while ago so I cant remember how exactly it was set up. /forums/images/graemlins/dunno.gif I think the biggest reason had to do with how tight the pads were on the rotor. There was tension on the pads (without the cable hooked up) and they were rubbing on the rotor, I actually wouldnt have known, but it sure stunk, really bad. /forums/images/graemlins/doah.gif I tried to adjust it but then the caliper fell apart (because it was 2 pieces or so I think /forums/images/graemlins/dunno.gif). I think thats how it went. Basically, I never got it to work.
