high angle drive lines
Discussion in 'The Garage' started by sledheadak, Jan 26, 2006.
  1. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    i just lifted my 84 jimmy 8" and thecv joint at the tcase on my front drive lines is going to bind.what deg of cv joint do i need to be able to keep it from binding?i can get a 37 deg cv here in town will thatbe enough? or do i need to order a shaft from out of state? i live in alaska so shipping will suck. thanks
  2. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    Campbell, CA
    call jess at high angle driveline (under vendors) or just grind the cv like i did to make it clear where it binds. If it has to work immediately thats what i would do but if you have time, just call HADL and they will make you a custom driveline with the angle provisions you need but im sure its coin.
