High Angle Drivetrain
Discussion in 'The Garage' started by clubba68, Sep 24, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    I was just wondering if anyone knows how much it costs to have a new rear driveshaft with e-brake built in from High Angle Drivtrain. I have a 70 K5 that is going to have a 4-6" lift. Rough estimates or however much you paid for yours would be helpful. Do they sell a kit to add in line driveline e-brake without having to buy a complete shaft? I have tried emailing them with no response. If you have any other companies you know of who make them that would be great too.
    Thanks,
    Andrew /forums/images/graemlins/usaflag.gif
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Give Jesse at High Angle Driveline a call. he will be able to answer you question better. High Angle Driveline /forums/images/graemlins/thumb.gif
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    It'll run you about $900 with a 1350 CV and a 1350 joint for the rear axle. That's what mine ran anyways. If you durrently have a CV rear shaft then I think you can exchange your flange for his special one that's needed for the e-brake, but yours has to be a 1350 CV.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Any idea what that'd run in a non-cv shaft? I have no desire for a cv shaft in the rear.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think my setup was a bit under $800 a few years ago when I bought it. You get a discount if you are a paying member of CK5 (10%...so you will have payed for the membership and then some). RyanB and I both have HighAngle 1-ton cv's w/ e-brake. You can look in the 1st gen forum about the install. To make it a easy install you will either need a body lift (like RyanB has) or to "clearance" the floor like I did. The e-brake works assome!!! It will stop me (with the tranny in N) on any hill my tires will hold on. Mine and RyanB's are clocked in the 11-O'Clock position.
    You can't get the e-brake without the 1-ton CV.
    Feel free to email me if you have any questions.
  6. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    I'm pretty sure that you have to run the CV to run the e-brake.
