High Angle Ebrake help.. UPDATED
Discussion in 'The Garage' started by SCJimmy, Nov 30, 2003.
  1. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    Trying to get mine installed...
    241 xfer case. JB Conversions SYE installed.
    I need a pic of one installed on a 241 w the sye.
    I have tried it with the spacers in front of the bracket, behind the bracket, etc. Even when I get every thing lined up, the 12 pt bolts going thru the disc to the cv flange are going to hit the bracket mounting bolts as the shaft rotates...
    Any ideas?
    Going to give Jess a call tomorrow...
    Thanks,
    Byron
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Re: High Angle Ebrake help.....
    Dood.... I got the same deal on my 205.... I tightened all the 12pt 12mm bolts down, and a month or so later i got this new clicking sound... It turns out it was those driveshaft bolts just barely backed out and they were hitting the other bolts for the caliper bracket mount...
    I just tightened em down again and they're alright... every once in a while when i hear that sound i know one of my driveshaft bolts has backed out about 1/2 a turn. /forums/images/graemlins/ignore.gif /forums/images/graemlins/deal.gif
  3. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Add some washers /forums/images/graemlins/tongue.gif
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hmmm. i'm trying to see the logic in that... /forums/images/graemlins/confused.gif
    The distance between the 2 bolts for the caliper mount and the 4 bolts for the driveshaft flange is really close... The heads of the bolts almost contact each other, adding washers to either of those bolts would make that distance even closer if not making them touch each other then. /forums/images/graemlins/deal.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/confused.gif
  5. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Loctite?
  6. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I was thinking the bolts were go too far through and hitting the disc..oopsie /forums/images/graemlins/blush.gif
  7. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Yes! /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
  8. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Ahhh. I understand yer thinking now. /forums/images/graemlins/smirk.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/k5.gif
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I am sure Jess will get you on the road but PM me if you still need pics.....
    What was/is the problem?
  10. SCJimmy
    Mar 7, 2003
    406
    Yep.. Jess got me straightened out.
    Apparently, JB Conversions uses several different vendors to machine the rear plate for their SYE kit. The plate I have has smaller holes in it than the plates Jess supplies.
    Since the ID of the holes are smaller than the OD of the spacers, the spacers would not seat into the holes in the plate, causing the caliper bracket to be too close to the rotor.
    The spacers he sent were correct, but too big for the plate I have.
    Jess offered to send a set of smaller spacers to me 2 day air, to get the brake on right.
    Yet another example of the first rate customer service High Angle provides.... /forums/images/graemlins/thumb.gif
    Thanks to all for the replies! /forums/images/graemlins/grin.gif
  11. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Jess RULES!
  12. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    best..driveline shop...ever. /forums/images/graemlins/laugh.gif
    j
