High angle front driveshaft.
Discussion in 'The Garage' started by Camo_crewcab, Mar 6, 2007.
  1. Camo_crewcab
    Camo_crewcab Registered Member
    Mar 4, 2007
    7
    Corvallis, OR
    Hey i have an 84 1 ton chevy crewcab. With a 10 inch. All the driveline shops want like 700 bucks for a custom made one. Does anyone know a cheeper way to get arround this?
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    134
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    That is pimp but I am still confused on the machining of the yoke and flange:doah: . That with a 1410 joint and long slip spline at the axle and I should be good to go. I do not use 4x4 on the road so I aint worried aboot a balanced front shaft:D .
    Oh anyone got any busted 60 outers with good ears on em:D
    Ira
  4. Camo_crewcab
    Mar 4, 2007
    7
    Corvallis, OR
    sorry im new to the boards, i cant find this explanation with pictures and stuf that your talking about.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    LIAM!!!!!!!
    welcome aboard. type in high angle and do a search on this site. Also I'll have to find my other extra shaft as I had one my brother was gonna do but it doesn't have a CV just a single joint on each end.
  6. 1977k5
    May 26, 2003
    9,995
    134
    I'm pretty sure only members can search now.
  7. 1977k5
    May 26, 2003
    9,995
    134
    It involves cutting up dana 60 axle shafts and using them and a 1480 u-joint to achieve ~40 degrees of driveshaft operation.
    Pictures are at the bottom of this page:
    http://www.pirate4x4.com/forum/showthread.php?t=549625&page=2
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    You play big, you pay big.
  9. Camo_crewcab
    Mar 4, 2007
    7
    Corvallis, OR
    ok so what about it makes it able to run at a 40 degree angle. It just looks like a very strong, home made single U joint at each end shaft?
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    the more working angle comes from the "depth" of the u joint ears being set off from the shaft. where as your CV is pretty much u joint on u joint.
    it's a nice idea just not too streetable.
  11. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    kind of pricy at first but better in long run. i found a ih truck with divorced 205 and all frame mounting brackets. as thay are 34" frames like are chevys are.
    mount the case dead middle of front and rear axles and have some nice drive line angles and can flip shafts around if needed if ya blow one up.
    only thing is you will need to swap to 2x4 tranny.
    i will be doing this in a crew cab soon with about 9" lift.
  12. 1977k5
    May 26, 2003
    9,995
    134
    1310 u-joints can run at a max of 30 degrees. 1350 u-joints can only run at 20 degrees. What is shown, 1480 u-joints using the yoke off of dana 60 shafts, can run ~40 degrees. The 1480 joint and the yokes off of the dana 60 axle shafts are designed to be part of the steering, which is why they have high angle capacity.
  13. muddermilitia
    muddermilitia ThatTrazerGuy GMOTM Winner
    Nov 10, 2005
    5,742
    76
    NE Illinois
    sorry to hi-jack but what angle can 1410 u-joints run at?
  14. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I think it's about 32-34 max.
  15. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    Camo crewcab
    Welcome to the site. Just going to throw this out there, but Tom Woods has a new ujoint that you may be interested in. It is suppose to give you 10 more degrees. I have no experience with it and have not heard any feedback on it. It may help you out a little. I just spoke to Jess at High Angle Driveline yesterday about my new shafts. I am going that route. Jess is the man.
    Here is the link to Tom Woods site. Click on the "superfex ujoint" link in the middle of the page: http://www.4xshaft.com/index.html
    Eric
  16. Camo_crewcab
    Mar 4, 2007
    7
    Corvallis, OR
    ok so i just managed to make a shaft off a suburban fit. It required shortening, and the U joint needed to be ground out in a few places. But i put it on this morning and i took it out and raged it arround and it did fine. So i think im going to stick with this for now and see how it holds up.
  17. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    what about taking some coin and doing a doubler. then your front shaft just became like 8-10" longer and will run at less angle and your'll have something to show for it.
