High Beams on Seperate Fuse?
Discussion in 'The Garage' started by tremor, Apr 6, 2004.
  1. tremor
    tremor Registered Member
    Mar 20, 2004
    10
    CT
    I know. Dumb Newbie question. I changed both highbeam lamps tonight. Both of the old bulbs were cracked. Neither worked before nor do the work now. I haven't checked Hayes yet. Are they on their own fuse? Relay?
    Thanks,
    Steve
  2. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Not a dumb???
    Welome to CK5. /forums/images/graemlins/waytogo.gif
    It helps to fill out your profile. I'm on dail up and it takes forever to do a search on ya to see what you have. /forums/images/graemlins/grin.gif
    It sounds like ya have a high beam switch problem.
  3. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I had the same problem and it turned out that the connector that plugged into the lens was corroded. Try cleaning the connections and see what happens
