High beams wont turn off...any suggestions?
Discussion in 'The Garage' started by 90K5, Nov 29, 2002.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    My blinker/wiper/high beam/cruise stalk has become broken and the high beams are the only lights on, and i can't switch back to the lows. Where is the high beam switch in the dash? Also, could i just switch the lights or wiring in the front of the truck so the lows are on? or are the PN's for all the headslights the same? I dont have time or any desire whatsoever to tear apart the column and fix this weekend...oh yeah my steering wheel doesn't really lock anymore when the ignition is off...
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    dont know if your is the same as mine but my hi beam switch is on the floor kind of next to the brake i did not know what it was for awhile i did not know i was driving around with high beams silly me
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    no mine is a switch on the column stalk, has a rod that goes somewhere...really not feeling like working on it out here, but i have to drive 350 miles on sunday...hopefully without the high beams on.
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    I have a similar problem, only I don't have high beams. Don't know it for a fact, but I suspect you can switch the connections on the lights until you can replace the switch. Replacing that switch is not fun.
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    nevermind i got it.
  6. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    How'd ya fixit? /forums/images/graemlins/1zhelp.gif
  7. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Just messed with the rod using some needle nose pliers...got the lows back on...it took awile though...
