high but no low beams?
Discussion in 'The Garage' started by cochino12, Mar 10, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I can get the high beams to work and all four lenses are on. when I change to just low beams the all turn off? any ideas
  2. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I had the same problem. Replaced the switch on the floor for $10. Also check the clips on it too. They go bad.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Also check the upper bulbs. They have TWO filaments; one for the low beam and one for the high beam. If both of the low beam filaments are burned out then you'll have no low beams. /forums/images/graemlins/eek.gif /forums/images/graemlins/wink.gif
