High clearance Headers?
Discussion in 'The Garage' started by Sandman, Jan 9, 2003.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    The dynomax headers I have now hang down pretty good and end up somewhat close to the crossmember. With the addition of the "L" bracket going on (end of 205 to the frame), looks like I could use a higher clearance header. Anybody know of a good one for a Big Block? thanks.
  2. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    Doug Thorley Try-Y's are good headers and have good clearance on small and big blocks /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gifThere was a post on this same subject about a couple of weeks ago. Try a search it will probably come up /forums/images/graemlins/thumb.gif
    Eric /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  3. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    But I like Posting! /forums/images/graemlins/grin.gif
    I did and some people liked the Hooker headers as well for the clearance. Just looking for more directed input on the clearance issue.
  4. OL14BLAZ
    Aug 14, 2002
    1,815
    TEXAS, USA
    I can tell /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif J/K!! PM Shawn Sprinkler he runs them on his K5. He can give you alot of input from first hand experience /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif /forums/images/graemlins/pimp1.gif
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'll second the vote for the Doug Thorley TRI-Y headers. A guy down the street from me has a set on a 454 in a 79 steepside. 205 T-case. Pleanty of clearence.
  6. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. I'll look those up too and see what I can find. /forums/images/graemlins/thumb.gif
  7. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color="blue">I used to have the same dynomax headers until I banged the passengers side one on a rock and bent the collector flange on my exhaust pipe. I replaced them with a pair of Summit headers (made by Flow-Tech) for a 88-98 fullsize 1/2 ton 4x4. I think they will also work with Vortec heads. I had a 3" Y-pipe bent and added a single flowmaster muffler in between the t-case and framerail. My exhaust guy bent the y-pipe up nice and high and the muffler is protected by the t-case crossmember. Here's a pic of one of the headers. You can see how the collector doesnt even go below the frame rail
    Here's the muffler tucked up next to the t-case. There's a turn down now, but I still need to have a tailpipe made
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Now thats what I had in mind! Thanks! It looks like that header was designed to bolt up to the stock exhaust. do you know if that is how it is?
  9. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Is that on a Small Block? On my small block I didnt have any troubles. They only came about when I went to the Big Block. /forums/images/graemlins/tongue.gif
  11. Longhorn4x4
    Longhorn4x4 Registered Member
    Oct 19, 2002
    67
    Tennessee
    I ran Hedman part number 68190 on my late model (77) truck with a 454. Those headers fit a big block Camaro, by the way. They are almost up against the floorboard.
  12. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    Thanks. I'l check those out too. I have a 3" body lift, so that might work out well.
  13. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I've got a set for a Big Block Chevelle. Maybe I'll try those. I know they dont work normally but maybe with the body lift they will.
  14. Shawn
    Shawn 1/2 ton status Premium Member Author
    1,753
    5
    5280'
  15. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    How high in relation to the crossmember does the passenger side collector come out? Also, how close is it to the crossmember? Thanks.
  16. Shawn
    1,753
    5
    5280'
    The passenger side on the Thorleys is really high. I'd say 2-3" above the crossmember. That one you won't have an issue with. It was a little close to my fuel lines but I wrapped them in the heat blanket stuff and no problems. The drivers side comes down lower and the pipe coming off the collector has to be bent up to go inside the crossmember. Plenty of room to allow the shackles to move and no front shaft issues. The only thing I don't like with the Thorleys is the 2.5" collector. For my 496, I'd like have 3". I'm going to try the Sanderson shorty headers soon.
